SDA for your turntable
F1nut
Fosgate strikes again. He has been on the edge with his processing skills. I wonder if he ever SDA'd in the past?
Thanks Jesse. I am a vinyl guy and this looks pretty cool. It is very difficult to send up a cartridge perfectly and this looks like it can help. I found this demo link:
https://www.youtube.com/watch?v=3kr_x26E5eE Living Room
Parasound Model 2250v2 amplifier
Parasound P5 preamp
Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
Schiit Mani Phono Preamp for Turntable 2
Oppo UDP-205 CD/SACD USB and FLAC duties
Technics RS-1500US reel to reel
Polk SDA SRS (2nd Gen) fully modded -
I might have to try one...
Priced reasonably. InterestingKlipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Been looking at that for a while. Was wandering if it might be like running SDAs with Sonic Holigraphy; ie not a good match. Would love to find out though.
I think it would pair up well actually. The crosstalk this device works with is at the source, while SDA deals with what arrives at the listeners ears after the signal is set free into the room. The Foz is not trying to correct the signal at the speaker like SDA and SonicHolography do.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Nice.
Anyone know's the name of the song?
CheersHTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV. -
And don't tell me that you heard a difference.....
Cool concept though._________________________________________________
That was a noisy record!
We saw / heard this in the Jolida room at AXPONA last April. My wife noticed a slight difference between it being in the signal path vs not.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
That's closer than the rest of us, were your impressions favorable?We saw / heard this in the Jolida room at AXPONA last April. My wife noticed a slight difference between it being in the signal path vs not.
I didn't notice a difference. That said, my wife's ears are better than mine and she's not into audio (she is a musician). We didn't have a vinyl setup at that time so we didn't have a dog in the race.
The way he explained what it attempts to do made sense at the time.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Is this a problem for TT? I have never heard cross talk in mine.Speakers: SDA-1C (most all the goodies)
Nice.
Cheers
Soundhound sez 'Here but I'm gone' by Vanessa Fernandez.McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable. -
Thanks.
I'm wondering.... If this approach is similar to what SDA is doing, then maybe this explains why vinyl sounds so damn good on SDAs?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
This seems to function as a balance pot, while it will provide some improvement (balance correction) to some turntables that do not have the capability to adjust the arm for azimuth, it does not correct the root cause.
I have a couple turntables this unit can probably help....
Has anyone purchased it? -
Has anyone tried one of these gizmos?Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
It's 100% guaranteed?....hmmmmYep, my name really is Bob.
Parasound HCA1500A(indoor sound) and HCA1000(outdoor sound), Dynaco PAS4, Denon DP1200 w/Shure V15 Type V and Jico SAS stylus, Marantz UD7007, Polk L600, Rythmik L12 sub. -
Play one of those old Beatles records, where all the sound is one just one channel, such as a vocal, and then turn balance to other channel. You will hear the sound that should be on just the other channel but at a reduced level.
On the CD version, it is completely isolated. -
Jesse I thought you are allergic to vinyl?Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
Ah-chooPolitical Correctness'.........defined
President of Club Polk -
He is allergic to direct sunlight exposure as well...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »
yes but is he self sealing after the fact?
