cannot hear volume on commercials yet TV shows are very loud
Help- cannot get this figured out. When watching live events on TV like the Golden Globes, Rose Bowl, etc. the announcer sound is fine, singing cannot be heard, and commercials are completely inaudible unless I blast the volume. I have had Best Buy out to my house a couple of times and have turned up the voice control to high but no avail. I have also turned off the sub woofer, but that only gave a little improvement. Thought on how to fix??
Jeff
Answers
  • daddyjt
    daddyjt Posts: 3,189
    can you tell us a little more about your system? Sounds like an issue with center channel matrixing- do you have an avr? Do you have a center channel?
    ― Aleksandr Solzhenitsyn
