FS: Grant Fidelity TubeDAC-11
markmarc
Grant Fidelity TubeDAC-11 $180
Here is a great way to introduce yourself to the DACheadphone amp world at a bargain basement price. The TubeDAC-11 is the second generation model with numerous improvements over the previous 9 model. The internal layout was cleaned up and organized. Three digital (SPDIF, USB, OPTICAL) and two analog inputs, with headphone and two RCA outputs, one of which is for the tube experience (to hear it on headphones you’ll need RCA to stereo ¼ female headphone. Last price new was $379, I’m selling for $180 which includes ground shipping CONUS in its original box. Below are links to reviews and specifications:
http://stereomojo.com/Grant Audio Tube DAC11.htm/GrantAudioTubeDAC11.htm
http://www.positive-feedback.com/Issue58/tubedac11.htm
Input: Optical, Coaxial, USB,Analong x 2
Input digital signal format: 32-192 KHz, 16/24 Bit auto detection. (USB 2.0 supports up to 24Bit 96KHz)
Output: DAC output, pre line output , tube buffer output.
SNR: >120dB.
Dynamic Range: 115dB.
THD+N: <0.0008% at 20-20KHz (tube out :0.02%)
Frequency response: 20-20KHz -0.2dB.
Output Level: DAC output: 2V, pre line output/ tube buffer output:max 6V
Output Impedance: Line out and Tube out - <20 ohm, DAC out < 600 ohm
Headphone output power: 110mW at 300 Ohm, and 600mW at 32 Ohm
Channel separation: DAC and Headphone output - 105dB; Tube output - 90 dB
Power consumption: <20W.
Net Dimensions: 10" W x 7" D x 2" H
Net Weight: 1.6Kg (3.5 lb)
Package Size: 12" W x 12" D x 4" H
SNR: >120dB.
Former Staff Member TONEAudio
2 Ch. System
2 Ch. System
great little dac that can also be used as a preamp.Amplifiers: Norma IPA 140, MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800
Puritan PSM156 -
PM sent
SOLD!Review Site_ (((AudioPursuit)))
2 Ch. System
