Can I drive a pair of SDA 2s and RTA 12s at the same time with an Adcom 555 amp?
gary_blevins
I'm currently running a pair of SDA 2s and RTA 12's, each with their own Onkyo TX-8511 receiver fed through a Y connector to the input source; assuming neither receiver could handle the low impedance of both sets of speakers together. Listening to mostly psychedelic rock & I love the 'fully immersive' sound I'm getting. I'm thinking about upgrading to an Adcom 555 and wondering if 1-it will adequately drive both sets of speakers simultaneously, 2-since there is only one set of speakers outputs, using a simple A/B switch to drive both sets of speakers. A quick search shows that most available switches max out at 150 wpc. I certainly don't need more volume but looking for more clarity, separation and 'pop' I assume the larger, cleaner amp will deliver.
Best Answer
If it was me and I wanted to drive more than one set of speakers I'd look for a multi-channel amp. I would think if both of those speakers are 4ohm that amp might see a 2ohm load.
Answers
I can't drive 555.
Neither could Sammy apparently. Just saw him driving the very car that inspired the song on Jay Leno's Garage.
You'll get that by using one pair of speakers and a good amp. Two pair of speakers will get you a smeared mess.Political Correctness'.........defined
President of Club Polk -
Yep, use the amp on one set of speakers, not both.HT SYSTEM-
lsi 9's -
Agreed with the above..........only a real **** would run 2 pair of sda's in the same room
motorstereo wrote: »Agreed with the above..........only a real **** would run 2 pair of sda's in the same room
WOW a little over the top no?
Just to clarify he's only running one set of SDA' s the other is RTA 12's
^^^^^^^Sorry I wasn't poking fun at him.........it was me that did that dirty deed many years ago. Having been there done that my advice is don't do that
I remember........LOLPolitical Correctness'.........defined
You could try running your source into the Onkyo and then an RCA from the tape out on the Onkyo to the Adcom. Keep one pair on the Onkyo and the other on the Adcom.
Those who know more than me will probably jump in and explain why this might not be a good idea.HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
Occasionally I'll look back at some old pics of my early days with sda's and wonder what the hell was I thinking............2.3s sitting on top klh12's, sp3500's stacked on top of the 2.3s, CRS's plopped on top of 2.3s........ OP listen to the good advice given by others here; 1 amp and 1 pair of speakers. -
Enjoyed the back and forth; even the **** part. It did help me clarify something. With the cable connected between the SDAs I certainly do have a 'smeared mess' and a bigger, cleaner amp isn't going to change that. I'll buy the Adcom and use it with the 12s or SDAs; not both. BUT, KLHs and Polks IN THE SAME ROOM???? And admit it on a Polk forum?
gary_blevins wrote: »BUT, KLHs and Polks IN THE SAME ROOM???? And admit it on a Polk forum?
Not only that I adamantly defended my position of doing that foolishness. Hey I'll admit I was wrong. Through all that I did learn from my mistakes and gain an education of just how bad a nice pair of sda's can be made to sound.
motorstereo wrote: »^^^^^^^Sorry I wasn't poking fun at him.........it was me that did that dirty deed many years ago. Having been there done that my advice is don't do that
Dang i forgot all about that.
I can't believe the SH made it through actually. -
Apparently the forum censors approve of s h i t if head comes along with it.Proud and loyal citizen of the Digital Domain and Solid State Country!
Well Ray you may be on to something richhead works also....
I wonder if anyone has tried stacking 2 pairs of SDA CRS+ speakers (tweeters close together) with the MWs aligned correctly to get the SDA effect? Seems like it might be a good combo to try. Please don't call me a **** for thinking out loud.
- SDA 2BTL · Sonicaps · Mills resistors · RDO-198s · New gaskets · H-nuts · Erse inductors · BH5 · Dynamat
- Crossover upgrades by westmassguy
- Marantz 1504 AVR (front speaker pre-outs to Adcom 555)
- Adcom GFA-555 amp · Upgrades & speaker protection added by OldmanSRS
- Pioneer DV-610AV DVD/CD player
- SDA CRS+ · Hidden away in the closet
They call those SDA1c.... lol -
I was hoping for a 1.2 when I stacked 2.3s and CRS's. It didn't happen.
Bought the Adcom 555 amp & preamp and after 36 years of owning the RTA12s hearing what they REALLY sound like for the first time! Better bass, better highs and significantly better clarity and separation. Thanks to all for the advice.
********Post edited by motorhead43026 onSince we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
Idolizing a politician is like believing the stripper REALLY likes you. -
I have SDA-SRS 2's SDA 2b's Dynaco A25's and a set of Pioneer HPM-40's in the same room however...Not a one connected to the same amp or are they stacked or otherwise attached..So see as the OP found out it does work !! Lol
Woops, I just moved them...
