LSiM 702 F/X installation
Hello,
I am finally about to mount my 702's and was wondering what height others suggest?? I see 6 to 8 feet, is that to the bottom of the speaker or to the center??
What are others doing and what are your thoughts??
Thanks a lot!!
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
    EndersShadow Posts: 17,719
    I mounted my LSi F/X about 3 - 4 feet above the listeners ear, which would mean that 6-8 feet they suggest is from the floor upwards.
    As my HT is also my Family room, I mounted them pretty high up to keep them out of the way of folks heads when walking or sitting.
  • vmaxer
    vmaxer Posts: 5,120
    Floor to bottom of speaker, or to center of speaker?
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • mikeyb128
    mikeyb128 Posts: 2,885
    I did 3 feet from ear level to bottom of speaker with my lsi fx. Works fine for me.
    2 channel:
    Theater:
  • polk500
    polk500 Posts: 1,171
    I'm 8' to the bottom seems to work as well or better than when I had then at 6'
    Cheers
    Roger
  • 6 foot. I'm gonna run thru my DVD-A's now. :)
  • vmaxer
    vmaxer Posts: 5,120
    I think I will start at 6' to the bottom of the speakers. I am about 4' behind the listening point as well.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
