Cambridge Audio DacMagic Plus vs. Parasound Zdac v2
Folks,
Which would you choose for computer as source and Focal Alpha 80 as powered monitors?
Cambridge Audio DacMagic Plus:
https://www.cambridgeaudio.com/products/hifi-and-home-cinema/dacmagic-plus
Parasound Zdac v2:
http://www.parasound.com/zdac-v2.php
Focal Alpha 80:
I will have a very small dedicated audio room in the basement. Near field is the best option for this room, and I will use room treatments.
Thoughts?
  • Conradicles
    Conradicles Posts: 6,328
    Decided to go with the Focal Alpha 50 and Cambridge Audio DacMagic Plus. Room treatments from ATC.
    Now I have to figure out which isolation devices for the monitors. Happy New Year!
    EndersShadow Posts: 17,687
    Isoacouatic stands or Auralex Gramma pads if on a flat shelf, otherwise I'd look at Skylan Stands....
    If not for falling into a pair of Sanus Ultimate Foundations, that's what I'd have right now.
  • Conradicles
    Thanks Enders...IsoAcoustic that match the same size as the Alpha 50 will be my choice. Happy new year!
    Cool! As a FYI they also make some for subs, should you need one for your basement setup with that 18" Stereo Integrity sub. Might need 2 of them, but it would save your tile or laminate flooring (forget which you have).
  • Conradicles
    Nah, the sub is good. The ATS panels are what I really need. That room has horrible acoustics.
