PSW10 to Onkyo HT-S3800
Hello Forum,
I was curious if it's possible to hook up my PSW10 to an Onkyo HT-S3800 AVR. My previous AVR had a RCA output connected with a RCA Y cable to the sub but this new one receiver has regular speaker cable inputs.
Thanks for any assistance.
Welcome to Polk's forum. Yes, there's an easy way, just run a second set of right and left speaker wires from the front speaker connections, on the receiver, to the corresponding right and left speaker inputs on the sub.
Regards, Ken
I just want to clarify. Are you suggesting
AVR sub connector - output |--> left/right - input
Method one, it will wont be using the sub output on the AVR
Method two, it will be merging four connections into two
Found model info here: http://www.onkyousa.com/Products/model.php?m=HT-S3800&class=Systems
