Before this weekend deal only...lot of SAE, Yamaha, Dynaco.....pick up only..
Well, it is purge time and this time I am serious :) Will be going to a local thrift if not gone by this weekend. Local pickup in the Olympia/Seattle area...
1. Dynaco FM3--everything works, needs cleanup..cant use a tuner here in Dupont because of the two military bases :(
2. SAE 3200 Tuner--everything works, ditto to above :(
3. Hafler 120 Amp...works fine but one set of speaker terminals in the back is very loose..power switch does flicker...just used a power strip for it
4. Yamaha A-1000 Intergrated...flap missing...will power off after about 20 minutes. Have no idea and no skills to investigate.
$100 for the lot....you might also be able to talk me into a good price for a set of Allison 6's with refoamed woofers but the grills have two holes in them due to the tweeter posts....
Also...$125 for a KAB EV-1, with not only a VAC-Sweep Replacement Kit with set sets of sweeps but also an installation tool AND a Home Depot Big Bucket with attached small shop vac!! Such a deal :)
PM me or reply here in the thread...
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
    mhardy6647 Posts: 35,190
    I'm warmin' up the car ;)
  • lightman1
    lightman1 Posts: 10,797
    Pick me up when you get to Indy, Doc. I'll ride shotgun if that's OK with Mrs. Doc.
  • ken brydson
    ken brydson Posts: 9,015
    lightman1 wrote: »
    Too close to me for comfort. Covering bushes with plastic as we speak.
  • starkiller
    starkiller Posts: 2,723
    SheesH!! The Yamaha is an Integrated not Intergrated! My fingers keep betraying me...
    pitdogg2 Posts: 27,206
    nbrowser wrote: »
    If I had my passport...I'd be all over that Dynaco...damn!
    You wouldn't be the first to jump the border...at least you might go back lol
  • starkiller
    Just one more day you Seattle/Olympia folks!!
  • lightman1
    Where's Jake(zingo) when you need him?
    Yo! Jake!
  • lightman1
    Just chuck it across the fence.
  • starkiller
    If only....hard to do with my work injured right shoulder :(
  • bikerboy
    bikerboy Posts: 1,235
    I'd be interested in the dynaco if you still have it
    Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
    Bottlehead Eros
    CD: DIY Shigaclone
  • starkiller
    No, everything is gone and been donated...sorry!
  • bikerboy
    Ok thanks
    Bottlehead Eros
    CD: DIY Shigaclone
