Before this weekend deal only...lot of SAE, Yamaha, Dynaco.....pick up only..
starkiller
Well, it is purge time and this time I am serious
Will be going to a local thrift if not gone by this weekend. Local pickup in the Olympia/Seattle area...
1. Dynaco FM3--everything works, needs cleanup..cant use a tuner here in Dupont because of the two military bases
2. SAE 3200 Tuner--everything works, ditto to above
3. Hafler 120 Amp...works fine but one set of speaker terminals in the back is very loose..power switch does flicker...just used a power strip for it
4. Yamaha A-1000 Intergrated...flap missing...will power off after about 20 minutes. Have no idea and no skills to investigate.
$100 for the lot....you might also be able to talk me into a good price for a set of Allison 6's with refoamed woofers but the grills have two holes in them due to the tweeter posts....
Also...$125 for a KAB EV-1, with not only a VAC-Sweep Replacement Kit with set sets of sweeps but also an installation tool AND a Home Depot Big Bucket with attached small shop vac!! Such a deal
PM me or reply here in the thread...
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
I'm warmin' up the car
mhardy6647 wrote: »I'm warmin' up the car
Pick me up when you get to Indy, Doc. I'll ride shotgun if that's OK with Mrs. Doc. -
Too close to me for comfort. Covering bushes with plastic as we speak. -
SheesH!! The Yamaha is an Integrated not Intergrated! My fingers keep betraying me...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
If I had my passport...I'd be all over that Dynaco...damn!
You wouldn't be the first to jump the border...at least you might go back lol -
Just one more day you Seattle/Olympia folks!!Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Where's Jake(zingo) when you need him?
Yo! Jake! -
Just chuck it across the fence.
If only....hard to do with my work injured right shoulder
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
I'd be interested in the dynaco if you still have itMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
No, everything is gone and been donated...sorry!Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Ok thanksMain system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
