Ultrasonic Record Cleaning Machines $300.00
  • voltz
    voltz Posts: 5,384
    If you look at the 3rd picture you will see one of the vinyl spacers on the table and it will cover the label just fine and look at the LP's in the tank you will see how the labels are covered and they don't go into the water.
  • Willow
    Willow Posts: 11,216
    I figured as much. But this record cleaning is all new to me. Back when I was a kid we just played them never cleaned them.
    txcoastal1 Posts: 13,499
    Willow wrote: »
    Back then you were just bangin' your head and didn't care
  • voltz
    voltz Posts: 5,384
    edited December 2016
    Brian's design for the spacers and the way they hold the LP's is excellent. with the bigger knobs on them it makes loading and unloading the vinyl really easy.
  • pongshi
    pongshi Posts: 376
    I ordered a machine and a 6L tank on ebay and can hardly wait. It was mentioned that 45RPM (7 inch) cleaning is possible since this is adjustable but I was thinking about how you would accommodate the larger hole. I am guessing the best way to do it is with one of those plastic 45RPM adapters that converts the 45RPM hole back to the standard LP spindle size. Just curious how any of you who have the machine do it, if you are 45RPM collectors. Comments and/or ideas would be greatly appreciated.
    Living Room
    Parasound Model 2250v2 amplifier
    Parasound P5 preamp
    Turntable 1 - Technics SL-1210Mk2 turntable with Shure V-15 Type III cartridge
    Turntable 2 - Dual 1229 turntable, Dual AS-12 45 RPM stacker, Shure V-15 Type III cartridge
    Schiit Mani Phono Preamp for Turntable 2
    Oppo UDP-205 CD/SACD USB and FLAC duties
    Technics RS-1500US reel to reel
    Polk SDA SRS (2nd Gen) fully modded
  • voltz
    voltz Posts: 5,384
    I will try a few I have, I got a few Rolling stones 7inch in a box set..with try it out and get back to you.
  • muncybob
    muncybob Posts: 3,231
    I don't have a vac to dry the records. I did see a you tube vid where the tank is drained low enough that there is no liquid contact to the vinyl and then a small fan is attached to the end of the tank. Records are then rotating slowly while air dries the vinyl. Seems effective, cheap and easy enough to do....anybody tried fan drying?
    Yep, my name really is Bob.
  • any new advice on
    "Stainless Steel 10L Liter Industry Heated Ultrasonic Cleaner Heater Timer"s?
    Will 6L suffice? Anyone try the 60 khz unit of choice?
    I need direction here :#
  • any new advice on
    I use my 6L and it's just the right size for me. But I only own like 80+ records. And if you want to clean 4 at a time it can be done. It's just really tight fit and there's alot of surface area to cover for something that size. If you have alot it might be beneficial to go bigger. As for 60khz...I'm still leary on going that high.
  • clyde75
    clyde75 Posts: 5
    How can I go about contacting you ER308L? I'd like to purchase the kit. Thanks.....Clyde
  • voltz
    voltz Posts: 5,384
    I do not know if you have time left to do this or see this....but if you see this you might want to remove your email address ..I will send it to Brian for you...or ask Ken S to do it for you...
    you may get unwanted replies!
  • [Deleted User]
    [Deleted User] Posts: 10,716
    Might be a good day to USC some more records as we are getting a soaker in Cleveburg...
  • clyde75
    clyde75 Posts: 5
    Very confusing interface here on Polk forums. How do you PM someone?
  • FestYboy
    FestYboy Posts: 3,861
    You need to be on the full site. The mobile app doesn't allow PM.
  • vmaxer
    vmaxer Posts: 5,120
    FestYboy wrote: »
    Sure it does, i do it all the time.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • clyde75
    clyde75 Posts: 5
    How is it done then via the mobile site?
  • vmaxer
    vmaxer Posts: 5,120
    edited July 2017
    See the envelope at bottom left?? It is indicating i have 1 PM. Click on it to create a new one as well. @clyde75
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • FestYboy
    Oooohhhh, I'm a derp. :o
  • clyde75
    clyde75 Posts: 5
    Thanks.... much appreciated
  • clyde75
    clyde75 Posts: 5
    Looks like ER308L skipped town. So much for purchasing the kit to accompany the ultrasonic cleaner.
    clyde75 wrote: »
    Brian is around
  • vmaxer
    vmaxer Posts: 5,120
    clyde75 wrote: »
    He is around, probably busy. Give him some time.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    Toolfan66 Posts: 17,983
    He is around, he's been busy building his audio/stereo/equipment rack..
  • FestYboy
    Which is, so far, fantastic looking!
    He will be back..
  • i have also bought new vacuumm recently, it is amazing.
