why use vibrapods ?
  • mikeyb128
    mikeyb128 Posts: 2,885
    I used to have vibrapods under my mono blocks, I found sound stage slightly larger, but made the bass flabby, I removed them in the end, I prefer them with their own feet. They worked ok under my pre amp as it's a tubes unit. I ended up buying some black diamond racing cones (mk3), and made a nice improvement under my pre. For the 6 bucks vibrapods cost, it can't hurt to experiment with them. I kept half and sold the others which were scooped up in less than an hour.
    2 channel:
    Theater:
  • machone
    machone Posts: 1,573
    I suspect that my current rack design is lacking and any isolation will be an improvement.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
