Brass spikes for vintage Polk speakers
I stumbled upon these while looking for something else. I've not seen top quality solid brass spikes since Mye Sound stopped making theirs. The diameter is about one inch at the top and 1.25 inches tall with 1/4-20 thread, perfect for SDA's. The icing on the cake is the stupid low price.
http://solen.ca/products/accessories/spikes-stands/102-089/
    F1nut Posts: 52,009
    Of course, they will work for just about speaker with 1/4-20 threads.
  • sbb2112
    sbb2112 Posts: 134
    Main System
    Marantz AV8802A PrePro
    Marantz MM7025 Amp rear surrounds
    McIntosh MC7205 Amp center, ceiling and mid surrounds
    McIntosh MC300 Amp front mains
    Oppo 203 Bluray
    Polk SDA-SRS with VR3 monastery crossovers
    Polk FX1000 Mid surrounds
    Klipsch RP-440C Center channel
    Klipsch RP-15M Rear surrounds
    SVS prime elevation ceiling surrounds
    Rythmik F15HP sub
    Samsung 8500 curved screen 65" LED 4K
    Mac Mini Server
    Office System
    Musical Fidelity M6s dac/preamp
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
    F1nut Posts: 52,009
    edited December 2016
    Those are not the same high quality solid brass billet spikes. They are two piece spikes and the threads are a separate piece. There is a difference.
    pitdogg2 Posts: 27,340
    $7.90 each if my math is correct or about 63$ for 8. Very NICE Jesse
    The nice part about those from Oregondv.com is that I like the fact that the threaded part IS separate. I take a bolt of the proper thread and a large washer and tighten from the inside of the cabinet. They never come loose.
  • machone
    machone Posts: 1,566
    Pitdogg,
    How did you level your speakers?
    Bob
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    I tilt my head.....
    No seriously it's very easy my floor is level. If I did need to I would just brass washers on top of the spike. I dislike those aftermarket inserts that so many use. I had a very bad experience with some once that left a BIG hole in the bottom of a speaker.
  • vcwatkins
    vcwatkins Posts: 1,992
    Thanks for the link. I did not realize Mye Sound had stopped making theirs and I need at least one set.
  • sbb2112
    sbb2112 Posts: 134
    I had other spikes and did not care for them much as the SRS are heavy and the smaller diameter ones tended to fold over a little when laying the speaker down. It didn't take much side pressure and the spike was loose. The 1.50" from oregondv has enough footprint to not deflect when laying cabinet over and I am using a bolt and washer too. The tip of the spike screws out if leveling is needed. They look good to me, I got the black chrome, but then again you can't really see them much. Sound wise, a big spike like either of them, really is huge as far as improvement goes.
    Main System
    Oppo 203 Bluray
    Rythmik F15HP sub
    Mac Mini Server
    Office System
    Oppo 103D Bluray
    Polk SDA-SRS 2
    Parasound HCA-1500A
    Polk PSW 650 sub
    Microrendu
    Roku Ultra
    Mac Mini Server
    msg Posts: 10,473
    Do you guys recommend the coaster feet are required for spikes? Or just for wood/non-carpeted surfaces?
  • teekay0007
    teekay0007 Posts: 2,288
    msg wrote: »
    No coasters on carpeting, just on hard surface flooring.
  • agfrost
    agfrost Posts: 2,474
    The oregondv link has the 'coasters' on sale for a stupid-cheap price (one dollar per). Again, they're not as nice as the ones made by Myesound, but I couldn't resist for a total of about $15 delivered. Going to use them underneath spikes of the stands in my bedroom rig.
    Jay
  • With thick carpet and pad, do you need the taller ones? I have a set on mine but with the weight , they're still on contact with the carpeting. I also don't hear the difference, so I'm wondering if the tallers ones are the way to go.
    Sometimes you need to push the speaker down to get the spike to pop through to the floor underneath. Some spikes are not very sharp pointed that will be a problem if yours are like that. Taller thinner sharp pointed spikes will help. Look through oregondv link there should be another spike that can go on the spikes listed in link 4 . The link F1nut provided are going to be very nice Jesse never does anything halfarsed. The listed oregondv do come in two flavors of threads American and metric so shop carefully.
  • Schurkey
    Schurkey Posts: 2,122
    DSkip wrote: »
    teekay0007 wrote: »
    Please give me an imaginary pencil, so I can poke-out my mind's eye.
    Somehow I knew another thread about spikes...would turn into a thread about someone's spike.
  • teekay0007
    Ewww...all kinds of bad imagery here! :s
    Back on course, back on course...reroute!
  • boston1450
    boston1450 Posts: 7,758
    I Like Spikes :)
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
