What did I cook
Howdy All! it's been a long time since ive been on here and since I have really played with my SDA-CRS+ I got the brilliant idea to try an Audio Control amp. i use them in a lot of installs and I did not even think about it not being a common ground amp. Since my speakers have never been touched (no upgrades).... its time! I ordered Sonicaps etc. and new binding posts. I also ordered a torroidial coil to make a dreadnought. But what damage did i do but connecting to a non common ground amp so I can address it when I start my upgrades.
Thanks!
Chris
  • Moose68Bash
    Moose68Bash Posts: 3,843
    edited December 2016
    Have you tried the speakers with a common ground amp since the "incident?"
    I once connected my monoblocks to my (then) SDA SRS 1.2s with the standard SDA interconnect. When I heard the frighteningly loud POP that resulted when I turned on the amps, I was afraid I had destroyed the amps, the speakers, or both.
    However, regardless of the loud noise, everything worked well when properly set up.
  • It's all good! I rebuilt my crossovers. Waiting for tweeter for TL mod. New Jantzen 16mh inductors and I will make a new mounting plate for the crossover. May replace all the inductors, but a vendor told me I need a 200$ minimum order. I also built a dreadnouhgt to eliminate future issues
    F1nut Posts: 51,934
    What isolation transformer did you buy?
    Where did you attempt to order the inductors?
  • DR. SNOW
    DR. SNOW Posts: 26
    F1. i bought the original avel lindbergh dreadnought that darqnight made. i tried to purchase jantzen c core inductors from parts express. i ended up with standard jantzen perfect lay inductors from parts express. i was able to get the 16mh 18 guage wire but will have to modify the others with an lcr meter.
