Amps
Willow
I know, I know tons of talk on amps here.
I am currently using my Rotel 1075 to power my 703s. While it does a good job, I think they need a bit more octane. Plus I am using only 3 ch on the amp, soon to be down to 2 come next week as I'll be storing the csi5 along with all my other Rti gear. I almost jumped on the Sunfire in the FM but then thought why would I buy another 5ch amp only to use 2ch. I am not looking to passively bi-amp either, I just bought new to me MIT avt2 speaker cables so not looking at replacing them. I'm looking for a neutral to warmer sounding 2ch amp that is not large the size of my 1075. I'd be looking used and not more than 400-700 US. Less expensive the better but not a deal breaker. I know of the usuals will come up like Parasound, Bryston... So what do you guys think?
My current amp is 120wpc, I am looking for 200+ with. What are your recommendations.
Post edited by Willow on
guess you missed the 4-700 range not 4700
A used dealer here has an anthem MCA 2 but is asking too much from what I can see, 700cad.
sorry I thought 4-7 k
I have a parasound 1500A that I purchased from a polkie and never used. If that is an option for you shoot me a pm. its is rated 200W and seems to be highly regarded on this forum.
I really like the Menuetto with the 703, but I don't think it fits your desires at 60 wpc.
with the B&W 703?
Just trying to see how 60wpc could beat my 120 on my Rotel. ( I know other factors are involved)
http://www.canuckaudiomart.com/details/649298001-anthem-mca20/
Ontario
Listing date of September. He's a little high and has shipping factored in. Don't know how close you are to his location to save there as well...
I enjoyed mine when I had it.Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
Thought about anthem a used dealer has one but asking 750. I thought it was too much
Wagners HCA-1500 would be a very good candidate. I own one and it has plenty power @ 60amps.Patriotism is the last refuge of a scoundrel…….Samuel Johnson
– Kevin Alfred Strom -
Willow....I have a (recommended) Belles 150A amp that I could make available. Shoot me a PM if interestedMain Rig:
Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
Second Rig:
Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded) -
You should snatch up the 1500A and enjoy JF.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
If you're looking warmish - how bout a B&K Reference? 200.7 I think is 200wpc into 8ohms and doubles at 4ohms, I think one would be in your range and is pretty well regarded here. Just another option.VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Wagner is trying to find a good shipping box. We both don't want to risk any damage -
I'm familiar with the Rotel 1075 as that's the multichannel version of my old RB1070. I think you might be better off waiting for a good deal on an RB1090.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Holy hernia batman, 100lbs.
I plan on keeping the 1075 for the eventual rti 5.1 . -
On 2nd thought Willow....I think I'll hold onto the Belles 150AMain Rig:
Second Rig:
Perfect then.... get the 1090.
Then you can have a 7 channel system in case you want atmos.
Also, the 1090 has wheels in the rear... it's pretty easy to move around. Just lift the front and drag or push it along. Ingenious really.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
It would be great but not in the current budget and won't fit the current cabinet.
This leaves me right now with the potential parasound or the anthem which he has said he is flexible on his price. The other option is two smaller amps which can be used as monos . I'm looking into that as well -
It's done. The parasound is on its way. Thanks again @WagnerRC
Which parasound?Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
@WagnerRC is bad influence.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Thank Joey I found my other xlr cables.
I just coated my request for that amp with maple syrup and Canadian back bacon. He couldn't resist selling it.
