how to test speakers?
yupper
Answers
Hook them up.Political Correctness'.........defined
President of Club Polk -
Beat me to it, J.
duh,I mean can you test them otherwise?
Hello,
Here is a link to the excellent SDA Handbook, pages 32 and 33 will be helpful.
http://www.vr3mods.com/uploads/SDA_Handbook_2011_Rev2.pdf
Ken -
If you mean to just see if they work or not, a 9 volt battery touched to the +/- terminals will make the woofer move either in or out, depending on which way you hook it up.
If you mean testing for how well they sound, I like using either Fleetwood Mac's TUSK album or anything by Steely Dan.
To test for efficiency, play YES's Starship Trooper and listen to the opening bass riff.
A very efficient speaker will let you hear the trailing tremolo from the bass notes.
