Anybody kick the tires on
[Deleted User]
1) Legacy Calibre
2) Spendor D7
3) Dale Rubicon 5
My room is filled to the gills w/ (just about) all my worldly posessions. 16X15
90% music at this point. the floorstanders require a rework of the room.
I theorize the Legacy would be a drop in replacement for the 703's.
2) Spendor D7
3) Dale Rubicon 5
no?
how about
ATC - SCM40 v2 Tower Speakers? or any ATC for that matter. -
Thanks DSkip. I'm trying to squeeze out some bass as well.
Might have to give something up.
Just depends but u can probably work in some floorstanders but you'll need to watch driver integration and bass nodes.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
As it turns out I went 2 way bookies. "Large speakers, large problems" I'm not even
using the sub for two channel at the moment as I'm still deciding on whether to keep
them.
Supposedly, I could get a speaker that dips into the mid-low 30's
according to the rule of thumb formula for size of room....
