Anybody kick the tires on
1) Legacy Calibre
2) Spendor D7
3) Dale Rubicon 5
My room is filled to the gills w/ (just about) all my worldly posessions. 16X15
90% music at this point. the floorstanders require a rework of the room.
I theorize the Legacy would be a drop in replacement for the 703's.
  • [Deleted User]
    no?
    how about
    ATC - SCM40 v2 Tower Speakers? or any ATC for that matter.
  • [Deleted User]
    Thanks DSkip. I'm trying to squeeze out some bass as well.
    Might have to give something up. :#
  • Joey_V
    Joey_V Posts: 8,606
    Just depends but u can probably work in some floorstanders but you'll need to watch driver integration and bass nodes.
  • [Deleted User]
    As it turns out I went 2 way bookies. "Large speakers, large problems" I'm not even
    using the sub for two channel at the moment as I'm still deciding on whether to keep
    them.
    Supposedly, I could get a speaker that dips into the mid-low 30's
    according to the rule of thumb formula for size of room....
