Pennsylvania to Oklahoma
gwh
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Man that is way out in the woods. Not much out there. Bluefox might be close IIRC.Carl
You're correct in that Bluefox is way out in the woods, but he's out there in California.
Just curious, gwh, it's a great sub, but with a cooked amp that may run into some serious coinage fixing/replacing.
Sal Palooza -
I bought one local and really like the overall sound it produces and it has a high waf.
I have two good amps that fit this model, one new one used. DT still sells the amp but last time I checked they did not have the preamp but the guy I talked to stated the trinity preamp was the same thing and they had a few of those it just says trinity on it. I'll keep looking locally.
HT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Cogan House is actually not far from me, but unfortunately, I'm not headed to Oklahoma any time that I know of!
I believe @muncybob isn't too far either. Might check with him. -
mrbigbluelight wrote: »You're correct in that Bluefox is way out in the woods, but he's out there in California.
Yeah I guessed wrong, I know there is a member close to there.
Carl -
I used to date a girl from Cogan Station, PA.
It's a rural little village on the outskirts of Williamsport.
