Pennsylvania to Oklahoma
gwh
gwh Posts: 1,451
Any body from that neck of the woods road tripping West? ;)
http://www.ebay.com/itm/302136791493
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
  • schwarcw
    schwarcw Posts: 7,358
    Man that is way out in the woods. Not much out there. Bluefox might be close IIRC.
    Carl
  • You're correct in that Bluefox is way out in the woods, but he's out there in California.
    Just curious, gwh, it's a great sub, but with a cooked amp that may run into some serious coinage fixing/replacing.
  • gwh
    gwh Posts: 1,451
    I bought one local and really like the overall sound it produces and it has a high waf.
    I have two good amps that fit this model, one new one used. DT still sells the amp but last time I checked they did not have the preamp but the guy I talked to stated the trinity preamp was the same thing and they had a few of those it just says trinity on it. I'll keep looking locally.
    HT:
    Emotiva Airmotiv E2
    SVS SB16 Ultra
    Yamaha RX-A3070
  • scubalab
    scubalab Posts: 3,105
    Cogan House is actually not far from me, but unfortunately, I'm not headed to Oklahoma any time that I know of!
    I believe @muncybob isn't too far either. Might check with him.
  • schwarcw
    Yeah I guessed wrong, I know there is a member close to there.
    Carl
  • Gatecrasher
    Gatecrasher Posts: 1,538
    I used to date a girl from Cogan Station, PA.
    It's a rural little village on the outskirts of Williamsport.
