SDA-2B Caps
    F1nut Posts: 51,750
    It's not. The letter, in this case "J" indicates the tolerance, which is +/- 10%.
  • jdjohn
    jdjohn Posts: 3,351
    Ahhh. And so, A=1%, B=2%, C=3%,..., J=10%?
    Question about moving that winding: Will I need to reapply hot glue?
    pitdogg2 Posts: 27,037
    ok so I'm not nut's. I thought that was how I learned it.
    jdjohn wrote: »
    Buying the bigger boards from Dave (westmassguy) will make life much easier for this project. The factory boards will be a tight fit.
  • I used my original boards at first then purchased the larger gimpod boards when I decided to upgrade my inductors. The only issue with the original boards was fitting the SDA caps but it works. The gimpod boards sold by Dave are better quality and easier to work with but not absolutely necessary jmho.
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • jdjohn
    jdjohn Posts: 3,351
    I'm going to try with the stock boards first, but good to have a backup. Besides the old caps being different on my two boards, the undersides of the boards are also different...in color. One is the 'typical' green, and the other is blue.
    I should receive the new caps tomorrow from Parts Connexion - pretty fast shipping from Canada. But I think my honey-do list for the weekend is going to get pretty full with Thanksgiving next week and company coming into town to stay with us :/
  • Those boards were definitely built a year or so apart, I would guess your serial numbers tell the story
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • jdjohn
    jdjohn Posts: 3,351
    In with the new! That big-a$$ 40uF cap (top right) was the only real problem child. The second pic shows how I had to extend the lead a little on that one.
    F1nut Posts: 51,750
    Just one suggestion, strap that 40 down.
  • jdjohn
    jdjohn Posts: 3,351
    edited November 2016
    I wanted to, but there isn't an available hole in the PCB. Is it okay to drill one?
    F1nut Posts: 51,750
    Sure, as long as it doesn't break a trace. Another option is to use 3M VHB tape under the cap and between the cap and the inductor frame.
  • jdjohn
    jdjohn Posts: 3,351
    I used 3M double-sided foam tape. You can see it under the 40 in the pic with the scabbed lead wire.
    F1nut Posts: 51,750
    Yes, I saw that. It's ok, but nowhere near as good as VHB.
  • The vibration from the movement of the drivers may loosen that big capacitor causing noise and possible connection issues. A zip strap will add extra insurance.
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
  • jdjohn
    jdjohn Posts: 3,351
    Good to know for next time, especially since I was a little disappointed in the foam tape I used. I did put additional pieces between the caps and the inductor after reading your tip. One piece actually touches the inductor wire coil, but that should be okay since the wires are insulated. Adding those pieces gave it that extra bit of stability I was looking for, so thanks Jesse for that tip!
    While I was in there, figured I might as well give the PRs the Dynamat treatment.
    All sealed-up now and burning in with Muddy Waters. Sounding better and better as the caps mature...should be interesting. I'll go back in later and add Dynamat to the mids, and THEN I have two pair of Monitor10's that need the same treatment all around with caps and Dynamat...and maybe veneer... Thanks to all for your input along the way, especially the F1nut, Jesse!
    Funny out-take last night during this project: I was attempting to make a DIY adjustable soldering iron by using a dimmer switch/outlet combination in a switch box. Apparently I hooked up something wrong because when I tried to test it with a portable light, I tripped a breaker. Luckily all was well after resetting the main breaker.
  • jdjohn
    jdjohn Posts: 3,351
    Thanks, Randy. I might do that when I go back in to treat the mids with Dynamat. I just wasn't sure about drilling through the PCB, but hey, I guess they did it when they made it, so what's another hole or two? ;)
  • TennMan
    TennMan Posts: 1,267
    This might help when you start to drill. Nice work by westmassguy on my crossovers.
  • jdjohn
    jdjohn Posts: 3,351
    Thanks, TennMan. A picture is very helpful. I knew that one of those straps on the 40 had to be very close to the edge. Looks like you got the TL upgrade. I see how Dave mounted the 2.7 resistor underneath to make room for the additional cap on top...very nice. Now that I know drilling through PCB is routine, I will feel comfortable doing it myself, and can be creative as to where I place holes.
  • TennMan
    Yes, Dave did the TL upgrade for me. He does really good work. Once you have your cap upgrades completed and you have spent some time with them, I would recommend you consider replacing the large conductors with lower DCR inductors. Dave recommended it to me and it made a good improvement in the bass for the small amount of money spent. I used the Erse Super Q inductors but there are other brands out there that may be even better if you are willing to spend a little (or a lot) more money.
