How can I troubleshoot a tweeter issue in Polk 10as?
Tweeter in the left speaker is not working. Moved it the right and it works. Right tweeter does not work in the left speaker; so I'm assuming a wiring or crossover issue. I pulled the crossover and all solder connections seem tight. I have replaced frozen drivers in various monitors before but am limited beyond the simple solder connections to accomplish that. Any suggestions for what to look for?
Gary
Best Answers
    pitdogg2 Posts: 27,339
    Answer ✓
    do they have fuses? if so clean the fuse contacts and look at the fuse to see if it is good. You may need a multi meter as that wire is small and hard to tell sometimes.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,206
    Answer ✓
    Spray the fuse holder with contact cleaner and rotate the fuse to spread the cleaner. Still no sound...remove fuse and use a piece of wire as a jumper.
    SDA SRS 2.3TL's
    SDA 2B TL's
    Answer ✓
    Thanks for the quick response. There is a fuse on the back of the crossover but not on the tweeter itself. Does this still potentially solve the problem?
    yes that fuse is for the tweeter and yes ^^^
Answers
  • Thanks for the quick response. There is a fuse on the back of the crossover but not on the tweeter itself. Does this still potentially solve the problem?
  • Thanks for the help. It was the tweeter fuse. Placed a jumper wire in it and they sound great!
  • dkfreebird
    dkfreebird Posts: 1,186
    Be sure and get the right fuse put back in it to protect the tweeter. That jumper takes away the protection. I believe it is a 1amp fast blow.
    Polk 1.2tl's Modded with dreadnought
    Musical Fidelity M6Si
    North Star Intenso Dac
    Auralic Aries Mini Streamer
    Oppo 103
    Pangea PC
    Wireworld Equinox 7 interconnects
    Wireworld Equinox 7 Speaker Cables and Jumpers
    Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5&7 peerless,Polk R200,Usher CP6311.McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre
  • If you don't have contact cleaner the grey side of an office eraser is excellent for removing tarnish from metal.
    I clean vintage guitar hardware with one quite a bit.
    ScotchBrite (green pads) is great for tin contacts with oxidation (but not on finished chrome)
