Audio Research Dual 51
Not sure I'm in the correct place but does anyone know anything about this amp??
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404
  • vmaxer
    vmaxer Posts: 5,120
    A friend brought one by along with an Audio Research High Definition Stereo Control pre amp, model SP3 A1
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • The ARC D-51 and SP3a-1 are from the classic Audio Research era, especially the preamp. I believe I have schematics for them if you need. The pass transistor used in the preamp's power supply will often fail and require replacing and power supply filter caps should be checked out. I believe ARC offers service and upgrading to maintain the value. The preamp can sell for triple what it originally sold for.
  • vmaxer
    vmaxer Posts: 5,120
    Ken,
    Thanks a lot for the information. I will PM you my email as I would love to have the schematics for them. Not sure I will keep them or not yet.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • I'll ask my wife to scan them and send.
  • You should have received them.
  • vmaxer
    vmaxer Posts: 5,120
    I did, thank you much!!
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • rooftop59
    rooftop59 Posts: 8,120
    Now that's beyond awesome customer service; that's just a sweet gesture by a great member of the forum. U rock @KennethSwauger!
    Game Room 5.1.4:
    Bedroom 2.1
  • Glad to be of help, my wife did all the work actually.
  • vmaxer
    vmaxer Posts: 5,120
    Well thank her for me as well.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
    pitdogg2 Posts: 27,171
    Ken is a keeper for sure. A few years ago he came across some wire he thought was pretty decent. He posted a thread to see if any of us wanted to try it. A few of us did I was one and I am still using it, he put RCA's on it and ship all on his dime.
    GREAT GUY. There aren't many left at Polk like Ken and Kim. When Mark left and Helen retired I was a little worried but these guys ROCK.
    Ivan
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited November 2016
    Something I should have mentioned earlier, if the D-51 is going to be used with an SDA speaker then the connections will be different than usual. The negative speaker terminal should be connected to the amp's "4" ohm tap instead of the "0" tap. Then the positive speaker connection will be to the "8" ohm tap if the speaker is 4 ohm and if the speaker is 8 ohm then use the "16" ohm tap for connection.
    "pitgogg2" I'm glad you're still using the RG62 based cables, I made some a few months ago for myself for a long tape deck connection.
  • sucks2beme
    sucks2beme Posts: 5,690
    A few years ago I emailed a request for the manual for my ARC amp to ARC.
    I paid $10 for it. They sent me that and a set of original sales flyers.
    It included schematics.
    They also answered some questions about the best tubes to use with it.
    Hard to go wrong with any of their products.
