Lfe question
Can someone tell me a little bit more about lfe output. I have a denon 3808ci avr and I'm not sure if I should have it set to LFE or Lfe plus main.
Best Answer
nhhiep Posts: 877
I've this same AVR. if you have big full range main speakers and want to run them full range, then set to LFE. Otherwise, set to LFE+Main and select your crossover point.
In my case, I set my Polk 707s as Small with Crossover at 80hz. Set LFE+Main, so all the bass under 80hz from my mains go to the SVS SB13U sub.
Answers
In the sound menu setting the all the speakers to small also directs the lower bass to the sub.The term large means the full frequency range [high/mid/lows] not the spk. size.This is the usual recommend setting when using a powered sub.
Question: if you set your 707s for an 80hz crossover, what advantage is there to have the 707s, vs. 703s?
"Large" means your main speakers will see the full range of the L + R channels. "Small" means the sub will handle L + R frequencies below the crossover off point on the AVR. The LFE frequency range is 3-120Hz, and it is mono. There is no real benefit to adding it to your mains.
I used LFE+Main when I did not have a sub, but I had an external amp. Even so kept the volume lower, and I also ran the signal through another piece of equipment that had a subsonic filter to eliminate the "rumble only" frequencies the speakers had no chance of being able to reproduce.
2 woofers in the 707s are crossed at a much higher hz, something in the 200-300hz. So they're still active.
Plus, quality stands for the 703s are very expensive.
and the 703s aren't loud enough for my 2700sq space.
and I like big towers
See what you like.
The OP didn't mention what sub he has or what speakers.
Just cuz you have a sub doesn't mean it is any better than the fronts for bass.
For movies with scary LFE, ok, sure - neuter your mains and set them to small and the xover to 80hz.
For music - maybe set the sub to off, maybe set the the bass to be LFE+mains(set to large)...
Thanks for the input.
The 707s are louder than the 703s? I assumed they'd be just deeper, not louder. No? I haven't heard the 707s. I have heard the 703s.
If you would, please elaborate on the "quality stands" comment.
I know on paper, they're both 88dB sensitivity, but to my ears, the 707s are fuller, even when xover at 80hz
