My two 5.25 speakers do not work on my rtia9... somebody know why?
all the 7 inchs work and the tweeter to.
Best Answer
Answers
  • ken brydson
    ken brydson Posts: 9,002
    Check to make sure the straps between the binding posts are tight
  • Dany
    Dany Posts: 7
    I have not pulled the cross over but will do that and post a picture..Thanks
  • Dany
    Dany Posts: 7
    I have remove the straps because the speakers are biamplified
    F1nut Posts: 51,763
    Using an AVR? If so, they are not bi-amped.
    Your problem can only be a few things. Blown drivers, bad crossover components or a loose connection.
  • Dany
    Dany Posts: 7
    @F1nut i think it's the cross over.. i have to remove it to see. What can make burn a crossover?
    txcoastal1 Posts: 13,512
    In most cases, a heated/cracked/burnt sand cast resistor
  • Dany
    Dany Posts: 7
    @DSkip the cable are correct..I already did the test..Thanks
  • Dany
    Dany Posts: 7
    @pitdogg2 ok..now i'm trying to remove the cross over from my rti. I have remove the 4 screws but i can't pull more than 1 inch. probably the speaker wires retain it.Do i have to remove all the speakers and disconect them??? excuse my english,i'm french. I hope you understand me.
    pitdogg2 Posts: 27,041
    Dany wrote: »
    you may have to. I do not know for sure as I have not been in those speakers. Most speakers have enough wire to pull out more than that. Best bet is to label and disconnect the wires from speakers and remove the XO
    F1nut Posts: 51,763
    The wires are soldered to the crossover board and there isn't much slack, so yes, you will have to disconnect the wires at the drivers to remove the binding post plate/crossover.
  • Dany
    Dany Posts: 7
    @F1nut @pitdogg2 ok..now i have remove the xover from my tower and i can't see anything burn.. i have call polk audio for a new xover because i still think it's the problem. I made a lot of the test with the speakers and they seem good.
