Dumb Question
I just received a Plinius 9100 from Paul and planning to hook everything up this weekend. This is for my 2 channel set up, which currently includes a Rythmik F12.
As the Plinius has no sub output, was wondering the best way to connect the sub.
It does have pre-out jacks, and my first thought was to use something like this: https://www.amazon.com/gp/product/B000BATDZ2/ref=s9_simh_hd_bw_b2VRq_p23_d0_i2?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=merchandised-search-3&pf_rd_r=8GG9WJ7GGM02BTN8WM89&pf_rd_t=101&pf_rd_p=cb75ae75-a5e0-5ee5-b55e-05231d247881&pf_rd_i=597546.
However, wouldn't this just take all of the signal and send it to the sub, leaving nothing to go to the speakers?
I've scrubbed the internet, and the only other option I've seen is using speaker cables, which I'm hoping to avoid. Seems like this would be easy but it doesn't seem to be.
Any words of wisdom would be most appreciated.
2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s
  • Jaybeez
    Jaybeez Posts: 748
    DSkip wrote: »
    The amp section should still be in use even if you use the preouts.
    Great thank you!
    WiiM Mini
  • voltz
    voltz Posts: 5,384
    I hook my sub up the way from my preamp and/or integrated amp, I have always use 2 cables for the sub (1 for the left channel and 1 for the right).
  • Jaybeez
    Jaybeez Posts: 748
    voltz wrote: »
    Thank you
    WiiM Mini
