FS: Parting out SDA CRS
The cabinets on these have some damage and one mid-driver is bad. I don't have the time to fix them up, so I'm parting them out.
Payment via PayPal, add 3%.
Shipping cost to be determined.
(4) SL2000 tweeters. Three are 1985 originals and one is from 1994. $10.00 each.
(2) MW6503 mid-drivers. 1985 originals. There is a third one that passes the push test, but the magnet looks shifted. You buy the 2 and get the third free, if you want it. $30.00 each.
(2) SW102 passive radiators. 1985 originals w/grills. $30.00 each.
(2) CRS crossovers complete w/blade/blade sockets. $20.00 each.
(2) CRS/CRS+ grills w/logo. $40.00 each.
(1) Original CRS owners manual. $5.00.
(1) Original SDA blade/blade cable, between 15 and 20 feet long. I didn't measure it. $40.00.
    F1nut Posts: 51,997
    The two MW6503's are SOLD.
  • cortico
    cortico Posts: 587
    Hi, can I take the manual if it's still available?
    Thank you
    F1nut Posts: 51,997
    It's yours. PM coming.
    F1nut Posts: 51,997
    The CRS manual is SOLD.
    Still available:
    F1nut Posts: 51,997
    Still lots of great stuff available. See above.
    F1nut Posts: 51,997
    Slashing prices, this stuff needs a new home.
    (4) SL2000 tweeters. Three are 1985 originals and one is from 1994. $5.00 each.
    (2) SW102 passive radiators. 1985 originals w/grills. $20.00 each.
    (2) CRS crossovers complete w/blade/blade sockets. $10.00 each.
    (2) CRS/CRS+ grills w/logo. $30.00 each.
    (1) Original SDA blade/blade cable, between 15 and 20 feet long. I didn't measure it. $30.00.
  • Are the passives the same ones used in the later model CRS+'s?
    F1nut Posts: 51,997
    Yes, the SW102 was used in all the pin/blade CRS+ versions.
  • classic carl
    classic carl Posts: 662
    edited November 2016
    Why are there 4 crossovers? Do the effect drivers have separate xovers? I have a pair of CRS. The effect tweeter on the right channel speaker produces no sound, but it works fine in the other cabinet. Therefore, the issue appears to be in the crossover. I have the effect tweeters disconnected as recommended on this forum, so it's not an issue for me.
    If I decide to sell them someday, it might be easier if they work as designed.
    Mine are serial number 4775, not that far off from yours. I imagine the crossovers are the same? I read in another thread that the CRS were made with 2 different xover versions.
    Main System 2.2:
    Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
    (2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
    Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
    Home Theater 5.2:
    Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
    Winter Residence 2.1 (laptop system):
    Yamaha A-S301 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200
  • F1nut wrote: »
    nbrowser wrote: »
    Carl, I've got a guess that there are wired very similarly to my SDA 2s. They have the stereo crossovers and on a separate board inside the dimensional crossover parts live. I think it's a similar story in the these CRS's
    Thanks for the reply. That's what I was thinking. For $20 for these crossovers. it might be easier than to troubleshoot the existing ones.
    Main System 2.2:
    Home Theater 5.2:
    F1nut Posts: 51,997
    Nbrowser is correct about the two separate boards.
    Carl, Jupman wants the crossovers and SDA cable, we just have to work out the logistics. If that falls through you are next in line.
  • OK. I only need one if that's all he needs.
    Main System 2.2:
    Home Theater 5.2:
    F1nut Posts: 51,997
    I'll let you know.
  • What do you have left at this point, F1nut? Thanks!
    F1nut Posts: 51,997
    This is what is left.
    F1nut Posts: 51,997
    Still have the above available.
  • HzTweaker
    HzTweaker Posts: 1,041
    Guess I missed out on this on. MW6503 :/
    F1nut Posts: 51,997
    The tweeters, crossovers and SDA cable are Sold.
    Thank you!
    F1nut Posts: 51,997
    These are still available.
    Toolfan66 Posts: 18,184
    If you still have the grills I will take them..
    F1nut Posts: 51,997
    Larry, I'll send you a PM.
    F1nut Posts: 51,997
    The grills are going to a new home.
    STILL AVAILABLE.....
