Dayton SA1000
EndersShadow
EndersShadow Posts: 17,719
edited October 2016 in For Sale (FS) Classifieds
For Sale is my trusty Dayton SA1000 amp.
It was used to drive a ported sub for the past year or so. Gain level never exceeded 1/2 on the dial, and I take GOOD CARE of my gear. I've never been able to get the 12v trigger to work, its likely just something easy I'm missing, but I wanted to mention that up front.
Honestly its not that big a deal as I just left the amp on 24/7 and the LED isnt that distracting compared to say the display on a iNuke or Crown or QSC.
I am ONLY selling because I bought a different amp, so this one is being sold to buy more drivers and boxes.
This amp is capable of driving 2 subs total (it has 2 binding post connections), but only if the total ohm load combined is not LESS than 4 ohms, and it treats them as a single sub so you cant EQ them independently.
I have the original box and inserts so shipping is possible but not included in the listed price. I ONLY ship insured with signature required, so make sure you factor that in to your cost.
Asking price is 300 + shipping. These go NEW for 400 all day long, and even on eBay they are going for 330 give or take . I am willing to entertain offers, please send those via Private Message (PM).
Payment Methods: I prefer cash or Paypal, but am open to other payment options such as check or money order if I know you.
Below are some MANUFACTURE PICTURES and specs. I will get pictures of the actual item up shortly.
SA1000 Subwoofer Amplifier Rack Mountable
Quick Overview
The Dayton Audio SA1000 is a freestanding, high-power subwoofer amplifier designed for the DIYer, installer, and systems integrator. This unique monaural subwoofer amplifier delivers the raw power of a pro-sound amp, but with the features and flexibility of a dedicated subwoofer amplifier.
Product Highlights
• Patented tracking down-converter power supply for high efficiency
• Class AB output stage for clean, controlled output
• Low frequency parametric EQ allows you to boost or cut to custom-tailor the sound
• Sophisticated soft clip circuitry improves headroom and protects woofers
• Manual, auto, or triggered on/off for integration into any automated system
• Switchable subsonic and bass boost filters
• High pass output for looping signal back into distributed audio systems
Product Description
The SA1000 is a freestanding, high-power subwoofer amplifier designed for the DIYer, installer, and systems integrator. This unique monaural subwoofer amplifier delivers the raw power of a pro-sound amp, but with the features and flexibility of a dedicated subwoofer amplifier. It can be configured for stacking with other audio components, and includes removable ears for mounting in standard audio racks (2RU).
A Class-AB amplifier configuration provides the SA1000 with clean and controlled output. From an application standpoint, the SA1000's low frequency parametric EQ enables you to boost or cut to custom-tailor the sound to suit the listening environment. Sophisticated soft clip circuitry provides cleaner transient peaks while protecting your driver from over-excursion. The amp's switchable subsonic filter removes subsonic information from the signal, which tightens the low end response of some subwoofer systems. On-board bass boost filters enhance LF performance while leaving the parametric EQ function available to address room modes, like cutting an excessively loud room resonance. The high-pass outputs provide a user the option to feed the signal back into their other audio components or a distributed audio system.
Manual, automatic on/off or triggered 12V input modes allow easy integration into automated systems. The stealthy pop-out knobs on the front panel make adjustments easy, while minimizing the risk of accidental disturbance. The SA1000's subdued brushed black aluminum faceplate allows the amp to blend cosmetically with any type of audio gear. Accommodates RCA line-level inputs, includes insulated binding posts for the speaker outputs, and accepts a 12V trigger via a 3.5 mm mini-jack.
Product Details
Model Number SA1000
List Price $549.99
Color Black
Unit of Measure Each
UPC 844632078514
Warranty - Parts 5 Years
Warranty - Labor 5 Years
Product Height 4"
Product Width 17-1/2"
Product Length --
Product Depth 13"
Product Shipping Weight (lbs.) 30.8000
Amplifier Type Subwoofer Rack Amplifiers
Power Output 497 watts into 8 ohms, 950 watts into 4 ohms
Power Output (RMS @ 70V) Range --
Output Channels 3
Output Connectors Binding Post
Output Types 4 ohms, 8 ohms
Inputs 3
Input Connectors RCA
Input Impedance 12K ohms
Signal-to-Noise Ratio 98 dB A-weighted
THD @ Rated Power 0.92%
Parametric EQ Frequency: 18 Hz – 80 Hz
Bandwidth: 0.1 – 1 Q
Level: -14.5dB – +6dB
Phase Adjustment 0° – 180°
Low-pass Crossover --
Low Pass Adjustment 30 Hz – 200 Hz
Dynamic Range --
Frequency Response --
Efficiency 86%
Gain --
Bass Boost +3dB @ 25 Hz, Q=1.4
Voltage Requirement 120/230 VAC, 50 Hz/60 Hz
Auto-on Sensitivity --
Stand-by Power Rating 120V 24W; 230V 18.4W
Special Features Subsonic Filter: -3dB @ 18 Hz, Q=.8
-3dB @ 80 Hz, 12dB per octave
Post edited by EndersShadow on
  • Nightfall
    Nightfall Posts: 10,083
    @WLDock Do you need another?
    afterburnt wrote: »
    Village Idiot of Club Polk
    Depending on location I may be willing to meet up AND I may even be willing to sell my current sub and box in a package deal.....
  • WLDock
    WLDock Posts: 3,073
    Nightfall wrote: »
    At some point a second sub would be cool... especially a matching HT15. No chance this year... Too much going on with the family.
    WLDock wrote: »
    Nightfall wrote: »
    Cmon... you know you wanna :smile:
  • WLDock
    WLDock Posts: 3,073
    edited October 2016
    If I had the cash I would buy it and entice you to sell the HT15 as well. Are you planning to upgrade to HST's or DS4's?
    My cash flow is tight right now...new CUV lease and home remodel has me broke for awhile. I have not had a car note in six years...
    Oh, the HT15 is likely on the block as well, and even in the enclosure...
    Moving to dual sealed....
  • FTGV
    FTGV Posts: 3,650
    That amp is the Bee's knee's for diy subwoofing.Good luck with the sale Dan.
    bumping....
  • trj
    trj Posts: 320
    Very enticing, but cant buy it.
    I thought of pairing this with a couple of bass shakers but this will be too much power(waste) for the bass shakers. GLWS.
    Sony BDP-S6500 | Raspberry Pi 2 | XBOX One S | Wii --> Yamaha RX-V667 --> Adcom 5006 bridged to 175 watts for front LCR -- >Front: Polk Audio RTi8s | Center: CSi5 | Side Surrounds: RTi4s | Rear surrounds: FXiA4s | Cheap 12" sub woofer|Samsung UN60KU6300
    bump
    Sold pending payment
    SOLD (forgot to update this till now lol)
