Looking for 2x MW 6501 woofers for my RTA-12C
Hi!
As the title mentions, I'm looking for two MW-6501 speakers to finish restoring my beloved set of RTA-12C.
Let me know if you have anything that would do the trick.
Thanks!
  • miner
    miner Posts: 1,305
    are these the woofers that were in the RP20s?
    pitdogg2 Posts: 27,143
    miner wrote: »
    I do not believe so they were used in SDA's and RTA12's MW6600 may also work for you.
  • pitdogg2 wrote: »
    miner wrote: »
    I ended up ordering some 6503 from Polk as per their suggestion. That being said, I'll leave the ad up as I would much prefer to find some matching drivers.
    Cheers!
    1 Driver Type Q BL Compliance DC Resistance Fs
    3 MW 6501 1.47 5.96 N 3.25 E - 3N/M 7.75 Ohms 31 Hertz
    4 MW 6502 1.97 5.16 N 1.47 E - 3N/M 3.52 Ohms 44 Hertz
    5 MW 6503 1.82 5.24 N 3.55 E - 3N/M 6.54 Ohms 29 Hertz
    6 MW 6509 2.1 4.57 N 3.54 E - 3N/M 8.97 Ohms 30 Hertz
    7 MW 6510 1.39 6.32 N 3.41 E - 3N/M 6.57 Ohms 31 Hertz
    8 MW 6511 1.405 4.34 N 3.496 E - 3N/M 3.13 Ohms 29 Hertz
    9 MW 6512 1.905 4.99 N 1.588 E - 3N/M 3.466 Ohms 40 Hertz
    Seems different by looking at spec's
    I'm sure they would know keep an eye on ebay they do come up often.
    be sure to trim the rubber around the screw holes so you do not foul up the rubber.
  • Thanks for the specs... I was aware of the differences, but at this time, it's my best alternative to revive the RTAs.
    I'll definitely keep my eyes open for some 6501s.
    Cheers!
