Speaker Jumper Length
Aloha,
I hope all is well with you. I am wanting to make some speaker jumpers. Why, because I just want too. What lebgth do you recommend? I am guestimating about 8-10 imches should suffice. Your thoughts?
Brian
Marantz SR 5010
Kenwood DR-V5070
Polk RTi A9- Mains
CSI A6- Center
Elemental Designs A2-300 Subwoofer
Panamax M4300-PM Power Conditioner
Working on updating my set up :rolleyes:
    F1nut Posts: 51,789
    Depends on the speaker cable you use. Some stuff bends easy, some doesn't.
  • Willow
    Willow Posts: 11,233
    I have premade xlo jumpers that are stiff and not much longer than 6 inches. If that.
  • Derm
    Derm Posts: 95
    Happy New Year everyone!
    Rather than start a new thread I thought I would piggy back on this one for relevance.
    I want to make my own cable jumpers as well and figure 6-8 inches is ideal for my application (depending on flexibility of the cable).
    What would be an ideal cable gauge to use for the jumpers?
    I have read online that the jumpers should be matched in gauge to the speaker cables but that thought was not universal so I wanted to see what the consensus is here.
    Thanks for any feedback
    Speakers
    Front - LsiM707, Front presence - LsiM703, Future ATMOS - VS 700LS
    Center - LsiM706c, Rear surrounds - 80 F/X LS, VS 900LS. Sub - (pair) Klipsch R-12SW
    AVR - Yamaha RX-A3010
    AMP - NAD C275BEE
    Main HT - LG 4K 75”, Sony UBXP800M2
    Bedroom HT - LG 55" 4K, Philips BDP7501 4K UHD player , Yamaha SRT-1500 sound projector, Spare room HT LG 50” plasma, Yamaha BD-671
    Office - Pioneer X-CM56, Bose iPod dock
    In Storage - 4 - RTiA9, RtiA3, CSiA6, FXiA4, Blackstone TL1
    The only source of knowledge is experience. Albert Einstein
  • afterburnt
    afterburnt Posts: 7,892
    Hell the jumpers I made are less than 4 inches. I dont see any reason to go any longer than distance and flexibility dictate.
    pitdogg2 Posts: 27,064
    edited January 2017
    consensus here make them out of the same stuff your speaker cable is made out of.
    F1nut Posts: 51,789
    Same cable as your speaker cable and whatever length is required.
  • gp4jesus
    gp4jesus Posts: 2,019
    Keep it simple. Use the same as those connecting your AVR, keep them short as practical.
    Enjoy
    *all connected w/Premiere ICs
