Best match for RT35s
Hey guys, I was given a system from a friend that I'm looking to upgrade. The center channel is pretty lack luster so I'm looking to replace it. My front speakers are Polk rt35s so I'm looking for something that will match them. I see they suggest the csi a6 elsewhere, but my onkyo TX-SR506 only has 100watts for the center channel and Im concerned that won't be enough to power the a6. Any suggestions?
Best Answers
  • TCK
    TCK Posts: 231
    Answer ✓
    Cs400
    - SDA 2B (1989, Oak Tops, 194s, Spikes)
    - Monitor 7B (1982 Peerless, Sonicaps, Mills, BH5, JB Welded, Binding Posts)
    - (2) SVS SB12-NSD (Flat Black)
    - SVS SB 3000 (Gloss Black)
    - Pioneer SC-1222K AVR
    - Marantz MM 7055 (5 Ch Amp)
    - Pioneer PD-D6 SACD Player
    - Marantz NR1403 AVR
    - Sony UBP-X800M2 (4k Blu-ray)
    - Sony UBP-X1100ES (4K Blu-ray)
    - Adcom GFA 555 Amp
    - Monitor 5 (194s, Side Surrounds)
    - Monitor 5Jr+ (194s) {Storage}
    - LG OLED65CXPUA (4K OLED TV)
    - LG 55UN7300PUF (4K HD TV)
    - RT35i (Cherry)
    - (2 Pair) RT25i (Cherry)
    - CS400 (Center)
    - CS350 (Center)
    - F/Xi A4 (Rear Surrounds)
    - RT25 (Rear Surrounds) {Storage}
    - Audioquest Interconnects
    - Blu-Jean Speaker Cables & Interconnects
    " But boy do I remember the strain of her refrain " LG
  • ken brydson
    ken brydson Posts: 8,984
    Answer ✓
    CS400 is the best match. CS400i or a CS350LS will match pretty good as well. All have tri-lam tweeters.
  • scubalab
    scubalab Posts: 3,105
    Answer ✓
    You want to timbre match your front sound stage. The CS 400 would be the best match. You want to stay with the same product line. Check to see if you have the RT-35 or the RT-35i. If you have the "i", go with the CS-400i.
    The old RT line was best grouped like this (although I might be missing some...):
    RT-25
    RT-35
    RT-500
    RT-800
    CS-400
    FX-500
    ________
    RT-25i
    RT-35i
    RT-500i
    RT-800i
    CS-400i
    FX-500i
    ________
    RTi28
    RTi38
    RTi70
    CSi40
    FXi30
    FXi50
  • honestaquarian
    honestaquarian Posts: 3,260
    Answer ✓
    Welcome to the forum
    The group is right about the CS-400/CS-400i
    I own a pair of RT-35i's and also a CS-400 (*the main difference between the RT-35 and 35i as well as the CS-400 and CS-400i was the tweeter change and the change in the color of the woofers to blue.Same woofers otherwise*)
    I have a CS-400 for sale elsewhere on this forum btw.
  • Jimbo18
    Jimbo18 Posts: 2,348
    Answer ✓
    The CS245 is a good match to the RT35. I have one now and have had the RT35 in the past. I like the CS400 better but for a small HT setup, the CS245 is fine.
Answers
