RCM KIT!
  • StevieB
    StevieB Posts: 257
    edited September 2016
    jonicont wrote: »
    StevieB wrote: »
    Working great for me. I do put it through 2 rinses. Using my Spin Clean brushes. Got the squeeze bottles for under a buck in the baking section of Walmart supermarket. Set up in the bathroom connected to my listening room (second floor "princess" suite)pfk1r9zamddx.jpg
    So you clean and vac, rinse and vac x2? I've seen videos where the guy submerges the whole record in distilled water.
    McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
    gudnoyez Posts: 8,169
    msg wrote: »
    Hey Steve, did you ever get your Okki Nokki goat brush and the rest of the RCM cleaning stuff?
    I'm curious to hear how these goat brushes work out with wet/RCM cleaning.
    The goat hair brushes work great I use one with the cleaning fluid and one with the rinse fluid this little RCM does a good job. I have not gone to crazy with mine yet I cleaned approximately 50 albums or so. I Prefer the Record Doctor premix better than my home brew cleaning fluid it will take a little experimenting with the home made stuff. What record did you guys get on the platter base? I also got one of Nick's zerostat holders.
  • soundfreak1
    soundfreak1 Posts: 3,414
    LOL I got the mormon Tabernacle choir!
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
    Mine was China Crisis flaunt the imperfection never heard of them.
