RCM KIT!
I was looking at using tergikleen. https://amazon.com/gp/product/B019YI38Z2/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
Working great for me. I do put it through 2 rinses. Using my Spin Clean brushes. Got the squeeze bottles for under a buck in the baking section of Walmart supermarket. Set up in the bathroom connected to my listening room (second floor "princess" suite)
So you clean and vac, rinse and vac x2? I've seen videos where the guy submerges the whole record in distilled water.McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable. -
Hey Steve, did you ever get your Okki Nokki goat brush and the rest of the RCM cleaning stuff?
I'm curious to hear how these goat brushes work out with wet/RCM cleaning.
The goat hair brushes work great I use one with the cleaning fluid and one with the rinse fluid this little RCM does a good job. I have not gone to crazy with mine yet I cleaned approximately 50 albums or so. I Prefer the Record Doctor premix better than my home brew cleaning fluid it will take a little experimenting with the home made stuff. What record did you guys get on the platter base? I also got one of Nick's zerostat holders.Home Theater
LOL I got the mormon Tabernacle choir!Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Mine was China Crisis flaunt the imperfection never heard of them.Home Theater
