Santana IV - anyone have the SACD?
drumminman
How would you describe the SQ and where did you buy it?
Thanks!
Thanks!
well I bought Santana * self titled & * Santana Abraxas * are that are excellenta so I'd said buy it
or can you say "Oye Coma Va" 2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thanks, but looking for the new one. I believe there is an SACD, but can't seem to find out much about it other than the music is good. May have to settle for a redbook copy."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Acoustic Sounds only has the Vinyl listed, and 1 reviewer said it was a noisy pressing.
http://store.acousticsounds.com/d/113020/Santana-IV-180_Gram_Vinyl_Record2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
I just picked up the vinyl, it's recorded very well and got lucky in regards to noise.McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
I ended up buying the red book cd. The sound quality is variable. Some tracks sound good; others not so much.
The songwriting also varies (imho) from good to meh. Worth having, but not stellar."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
