CD Player biting the dust?
    F1nut Posts: 52,104
    Try cleaning the lens. Also check for a loose connection as you may have bumped one while inside.
  • kevhed72
    kevhed72 Posts: 5,184
    Alright....I spent awhile messing with it after cleaning the lens. It appears the laser pickup is actually hitting the bottom of the CD when a disc is pulled into the unit. I tried adjusting the height of the bottom disc which is spun by the motor....but now the bottom disc just pops off the spindle when trying to release from the top magnetic disc. ****. I'll try calling Teac repair Monday but this may indeed be toast.
    F1nut Posts: 52,104
    Sounds like you damaged the optical pickup somehow when cleaning the lens.
  • kevhed72
    It was doing the same deal prior to cleaning it....I dunno. Almost as if the entire optical pickup which slides back and forth is misaligned with the CD tray.
    Perhaps time to invest is a good transport...thanks for the tips though.
    F1nut Posts: 52,104
    Ok, sorry I didn't realize that. Highly unusual though.
    txcoastal1 Posts: 13,519
    kevhed72 wrote: »
    May have been the original issue???
    F1nut Posts: 52,104
    txcoastal1 wrote: »
    kevhed72 wrote: »
    Yep, so it would seem. I'd like to get my hands on it to see what happened.
    F1nut Posts: 52,104
    Looking at your last pic I can see the pickup hasn't come off the slides, so that's not it. I'm wondering if the bridge is sagging, maybe under the weight of the Dynamat? Can you tell if it is sagging?
  • kevhed72
    It's tough to tell....I believe it's the original issue where the noise was being generated from maybe the disc rotating and possibly rubbing against the lens carriage. I'll drop you a pm....
  • kevhed72
    I have a short, close up video of exactly what is happening but I can't post it here. If anyone is interested drop me a PM and I can send it to you....unless the mods here can allow me to post it on this page. Thanks....
    F1nut Posts: 52,104
    Got your PM and replied. Send me the video too.
  • leftwinger57
    leftwinger57 Posts: 2,917
    Kevhed, no help here on your cdp. I do have one complaint. You, it does seem have a gear signature. You need an electron microscope to see your gear. Could you redo it for the betterment of us all. I also had micro font and I forgot how to enlarge the thing but it worked.
  • JPete
    JPete Posts: 298
    Try a little lithium grease on the rails? Had an Adcom GCD 575 that started making clicking noise and not reading discs. A little grease got her going again.. ;) Just a suggestion as I'm no techie.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
  • Nightfall
    Nightfall Posts: 10,083
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 52,104
    Fixed.
    F1nut Posts: 52,104
    Playing an SACD.
    Playing a CD.
  • kevhed72
    Jesse.....thank you for repairing this player.....I alpreciate the help and enjoyed our audio talk the other day. You definitely know your stuff! Check your PM please....
    nbrowser wrote: »
    The question remains....what was wrong with it that Jesse fixed? Curious minds wanna know!
    That info cost mo' money ;)
