Tubes Mostly Preamp & Power Tubes
    heiney9 Posts: 25,497
    edited August 2016
    2.Amperex-12AX7-Gray Plate D getter-1-$40.00
    Can I see a pic of the Amperex 12AX7 d getter? Any codes?
  • Nightfall
    Nightfall Posts: 10,083
    3.Amperex-12AX7-Gray Plate Halo getter-1-$25.00
    33.Amperex 12AT7 France-1-$25.00
    Sold! @dromunds showed me the Amperex way. B)
    afterburnt wrote: »
    Village Idiot of Club Polk
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    Sure here is a quick pic. All the print on this one is gone but it has a Δ7E code on it with 4 seams on top so I assume it is a 1957 Heerlen made tube.
    Regards Snow
  • snow
    snow Posts: 4,358
    Nightfall wrote: »
    There all yours :)
    Regards Snow
    edited August 2016
    I'll take it. You're sure it;s a 12AX7? I only ask because I already have 6 - 12AU7 long plates made in Holland, so I really don't need anymore :)
    Also I'm looking for a single 1952/53 GE (Ken Rad) 5814. Black ladder plate, bent post square getter and metal clips on the plate tabs.
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    Hi Brock I am 99.9 % sure it is indeed a 12AX7 I tested it as both a 12AU7 and a 12AX7 and it is either a very weak 12AU7 or a strong 12AX7 most of the time if you test a 12AU7 as a 12AX7 it will test far higher then it should which tells you it it is not a 12AX7. On my tester a good 12AX7 will test anywhere from 1200 to 3000 at 1.0 bias volts a good 12AU7 will test anywhere from 4000 to 7000 if tested as a 12AX7 and if tested as a 12AU7 at 4.0 bias volts will test from 2500 to 4000 on average.
    You can always return this tube if you feel it is not a 12AX7 or if your just don't like it no questions asked I like happy customers :)
    Regards Snow
    So the only code is the delta 7E. No top line code? mCx = 12AX7/Ecc83; k6x =12AU7/Ecc82.
    What you say makes sense with the testing. I'll take it, no problem.
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    No, no top line of code sorry.
    Regards Snow
    Ok when you have a chance PM with the total
    Thanks!
