SDA SRS 2 Amp
CH46E
CH46E Posts: 3,595
Hi everyone. My name is Chris. I've had several Polks. RT55, RM7500 set, RT35, RT15. I currently still have my RM7500s.
Now I have a set of mint SDA SRS 2. I have not hooked them up yet. The only amps I have are a NAD 906 which has 3 power supplies and either runs 30x6 or 3x90 bridged watts. I don't nnow if it has a common ground or not, so I have not tried it.
My only other power source in my Yamaha Adventage RX A1050.
Right now I use the NAD 906 bridged to run my JBL L80t with new caps and resistors.
My question is about a amp to run the SRS 2. I was looking at the Parasound 2125 v2. It runs 150 per @ 8 ohm. (Plenty to run my L80ts) and 225 per @ 4 ohms.
Is 225 watts with a "high current" enough to really open up the SRS 2 ?
The reason I was favoring this amp is the ability to run "A" and "B" speakers with a switch on the front so I can switch between the JBLS and the Polks. The Carver M500 and 1.5t, 4.0t and Adcom GFA 555 can't do that.
Will I regret getting the 2125 v2 ?
Oh and are all the SRS 2 4 ohms?
Thank everyone. Looking forward to being a part of the community!
    F1nut Posts: 52,166
    The Parasound will be fine.
  • CH46E
    CH46E Posts: 3,595
    So this will be plenty of power? I see the 2250 v2 with a lot more power but it also cost a lot more. 225 is plenty for these?
    F1nut Posts: 52,166
    Current (amps) is what you want. Pick the one with the highest.
  • Schurkey
    Schurkey Posts: 2,122
    edited August 2016
    CH46E wrote: »
    WHICH SRS 2? Blade/Blade, or Pin/Blade
    CH46E wrote: »
    Bridged amps cannot be common-ground. You must not use it in it's bridged configuration. I don't know if it's common-ground when not bridged.
    CH46E wrote: »
    Does it have an impedance selector switch on the back panel? Yamaha has done that with other products. The switch will strangle the power supply in the low-impedance position.
    CH46E wrote: »
    If it's rated for a 4-ohm nominal load, it'll probably be fine. I expect you'll like it.
    CH46E wrote: »
    The M500 CANNOT be made common-ground.
    CH46E wrote: »
    Maybe. Kind of depends on your personality. You want speaker switching, so it seems like a winner at this point.
    CH46E wrote: »
    Blade/blade are 4-ohm nominal, very similar to the SDA 1B. Cannot be made compatible with non-common-ground amplifiers.
    Pin/Blade are 6-ohm nominal, very similar to the SDA 1C. This generation can use the isolation transformer in the SDA cable, so it can be made compatible with non-common-ground amplifiers.
    F1nut Posts: 52,166
    Moo........
    F1nut Posts: 52,166
    I don't know, you're the one at the farm market.
  • CH46E
    CH46E Posts: 3,595
    DSkip wrote: »
    I would recommend grabbing my a23 in the farm market.
    I'd love a Halo amp, but I'm really kind of leaning towards the AB switching.
  • CH46E
    CH46E Posts: 3,595
    I'll let ya know when they get here. As to blade blade or blade pin.
  • CH46E
    CH46E Posts: 3,595
    It appears they are Blade/Blade. Now that my JBL are sold I don't have a need or a want to switch A/B speakers.
    So...... Adcom GFA 555???? Or other suggestions in the $300 200 watt range??
  • Nightfall
    Nightfall Posts: 10,083
    edited August 2016
    Search your local Craigslist for B&K and Parasound, see if anything comes up.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 52,166
    You cannot sell anything here until you get 100 posts.
  • soulsurfer
    oops sorry :/
    Carver TX-11b - Carver 4000t - Carver TFM45 x2 - Polk SDA SRS 2 (094 tweets) - RSL CG 8^2 (Howard's XO upgrade + driver upgrade = 350w rms and amazeball toanz)
  • westmassguy
    westmassguy Posts: 6,850
    You might want to pull the woofers on one of them, and see what's in there. I've had two instances, a 1C and SRS-2, that were blade/blade, had split crossovers, but were in fact 4th generation.
    If all four woofers have identical model #s (most likely MW6510), they're 3rd generation. If two are 6510s, and the other two are 6511s, then you have 4th generation SRS-2s.
    If they're 3rd gen, you must use a common ground amp. If they're 4th gen, you can use non-common ground amps with an AI-1 or Dreadnaught.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Rex81
    Rex81 Posts: 193
    I'm going to get flamed (again) by people who haven't heard this amp, but due to your limited budget, I'm going to recommend a Crown XLS 1500. It drives SRS 2 effortlessly, and you can find a new old stock one for less than $300. I paid $175 for mine from Amazon, although they're out of stock now, replaced with a newer model. They're ugly, but reliable and efficient, and they sound great. I slightly prefer my tube amp, but the Crown is cheaper, quieter, more efficient, FAR more powerful, and the SDA effect is better on it, I think due to better channel separation.
    People who haven't heard it seem to love to comment on how cold and analytical they sound. I don't understand that either. Those that have heard it find it dynamic and accurate. Not the sweetest sounding, but I've compared it directly to a number of class A/B, class D, and tube, and it holds its own nicely. I think it's a great match for SRS 2 on a budget.
  • Nightfall
    THD of the XLS 1500 is greater than 1/2 a percent, THD of my B&K is 0.09%. I wonder how bad the Crown gets when pushed?
    afterburnt wrote: »
  • Schurkey
    I'd have expected MW6509s like an SDA 1B.
    Yup, just like an SDA 1C.
    Yes.
  • Rex81
    Rex81 Posts: 193
    Nightfall wrote: »
    The Crown doesn't get pushed. It delivers 525 wpc into the SRS 2 and they're 92db efficient. The power meters on the XLS barely blip at uncomfortably loud volumes. I guarantee you won't hear any THD.
  • DollarDave
    DollarDave Posts: 2,575
    Nightfall wrote: »
    Well...with distortion like that, it should settle the cable debate...
  • westmassguy
    DollarDave wrote: »
    Nightfall wrote: »
    There's a cable debate?
  • [Deleted User]
    Rex81 wrote: »
    Nightfall wrote: »
    Yes, it has the wattage, but does it have the current? :)
  • Rex81
    Rex81 Posts: 193
    Haha, you know I put more value on the current. But yes, it's got plenty of both. A crazy high damping factor doesn't hurt with the SRS 2 either.
  • [Deleted User]
    Rex81 wrote: »
    Here's an interesting read on wattage and current.
    http://www.atma-sphere.com/Resources/Common_Amplifier_Myths.php
    F1nut Posts: 52,166
    Rex81 wrote: »
    The difference between a damping factor of 50 and 1000 is so small that it is a non-factor. It only becomes an issue when the damping factor is around 10. Basically, that spec should be ignored.
    F1nut Posts: 52,166
    TForan wrote: »
    Rex81 wrote: »
    Be that as it may, there is no doubt that a high current amp easily outperforms a low one. Maybe Ohms law isn't the end all.
  • oldrocker
    oldrocker Posts: 2,590
    I have an xls1500 & a xls2500 and yeah they are butt ugly..
    Have ran both on my SDA's and yeah can get loud and sounds ok, lots a watts for not much coin.
    Then I got my parasound 2250 and I myself like that sound better.
    So, to each their own and whatever gets your groove on... B)
  • CH46E
    CH46E Posts: 3,595
    I'm keeping an eye on CL for a good amp. Lots of good amps in Tampa but I don't like driving to far.
    F1nut Posts: 52,166
    There are businesses these days called UPS, FedEx and USPS that ship all kinds of stuff.
  • CH46E
    CH46E Posts: 3,595
    Anyone have experience with Acurus amps?
  • boston1450
    boston1450 Posts: 7,758
    edited August 2016
    Not sure about those speakers.... I have the Acurus 200/3 & its a very nice amplifier. Ive read they can be bright with some speakers. To me the Acurus seems to blends well with SDA's ive tried in what little time i have had it. I used it on 1c's & crs+'s with great results till i got the Parasound 2250 (got it here). I am eventually going to be using it back on crs's when i get the Parasound preamp for the 1c's after the xovers are complete
    Post edited by boston1450 on
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
