lack of higher volume punch
JPSmario
I have a pair of SDA 2Bs that have been TL'd by the previous owner. now that I have a more tolerant neighbor (I live in a townhouse), I turn them up higher more often but I'm not getting the thumpage punch I did from the SDA 2As I replaced. some of the screws on the subs do not tighten; they seem to be stripped. Can this be causing lack of a good seal that would explain my issue? any suggested fixes? or should I be looking for other causes? I appreciate any guidance here as I feel I know only enough to be dangerous and don't want to jump to conclusions.
Thanks,
Jim
Thanks,
Jim
Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
Push in & hold the passive in. The woofers will come out & should stay out at least 3-5 seconds. If they go back to normal to quick you have a leak.... Hurricane nuts OR Larry rings may workRandy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Keep in mind. It could also be woofer & tweeter gaskets/screws also. If you remove the woofers & tweeters & the gaskets appear ok - keep them. Stock ones tend to last a long time & unless there is a tear or something-they should be fineRandy-Maine
by David WMG
sounds like you may have a leak as Boston pointed out try that. These are dependent on a very good seal around the drivers to get good bass.
Hey i just thought of something. Could the wire to the bass inductor come off ? Im no tech-so just a thoughtRandy-Maine
by David WMG
Screws don't tighten.....you've got an air leak.Political Correctness'.........defined
President of Club Polk -
Something is wrong with the disaster known as Vanilla...big surprise!
This thread has 5 replies, but only 1 view, which of course is not possible. There are other threads with the same issue.
thank you all for your quick responses. and apologies if this question duplicated previous threads; not only has it been a while since I've logged in, I've never had much luck with searches. thanks again!Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
If you can't get Larry's Rings, hurricane nuts will work just fine. If the speaker gaskets are not in good shape you can make new ones out of Armacell, available at Home Depot."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
