Good set of sealed cans cheap?
I have some Sennheiser HD 558 but I want some sealed to tune everything out. I had some Audio Technica ATH M 30 that seemed ok but gave them to my kid before I really tried them out. Any suggestions?
    txcoastal1 Posts: 13,514
    What's your budget Bruce???
  • afterburnt
    afterburnt Posts: 7,892
  • Nightfall
    Nightfall Posts: 10,083
    How about these guys? They haven't changed the design at all I think, they still look like a pair of headphones straight out of the 60's.
    https://www.amazon.com/Koss-Pro-4AA-Studio-Quality-Headphones/dp/B00004Z7G9/ref=sr_1_8?s=electronics&ie=UTF8&qid=1470539815&sr=1-8&keywords=koss+headphones
    afterburnt wrote: »
    Village Idiot of Club Polk
  • rooftop59
    rooftop59 Posts: 8,120
    Do you have small ears? Honestly I really like the sound of my sennheiser momentums that I am selling in the FM, and I know so do several other guys on the forum do as well, but I just can't wear them more than about 1-2 hours without hurting my ears. Since I basically sit at a computer, research, read, and write all day, I need somethign can wear longer. But I really wish they would work, because I like how they sound and they are closed back and more portable than my current cans. Anyway they might suit you...
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    I have dumbo size ears
  • Emlyn
    Emlyn Posts: 4,796
    I've used Sony "DJ" style closed back headphones for many years and been happy with them for the purpose. The MDR7506 and MDRV6 are two current examples that have been on the market for quite a while and still sell well. I'd go with the 7506. The similar Audio Technica models up through the M40X also look like acceptable knock offs. The M50X would be a step up, but are a bit above $100.
    https://www.amazon.com/Sony-MDR7506-Professional-Diaphragm-Headphone/dp/B000AJIF4E/ref=sr_1_2?ie=UTF8&qid=1470560960&sr=8-2&keywords=sony+dj+headphones
  • afterburnt
    Emlyn I was looking at the M40x since I like the M30x ok for what I got to know of them. Would you give the edge to the Sonys? They are ten bucks cheaper but that doesn't make or break me since I can't afford either in the first place lol
  • afterburnt
    edited August 2016
    The ones in my price range don't seem to have as good Amazon reviews as the above mentioned.
    Post edited by afterburnt on
    mhardy6647 Posts: 35,167
    Nightfall wrote: »
    Realizing full well that no on asked my opinion :-P
    The problem I've always had with the Koss Pro 4AA and their kin is that sense of having a vise squeezing one's head when wearing them. They sound OK but dang are they uncomfortable.
  • Nightfall
    edited August 2016
    Gotta have a tight seal for the 10Hz bass! B) I have a smallish head so it probably wouldn't be as bad for me.
    One of the Amazon reviews.
    NEGATIVES:
    1) Weight (about 3 or 4 times as heavy as most contemporary studio-reference headphones)
    2) Tight headband - as noted, the fit is fatiguing if your 'hat size' is greater than 7.
    3) The coiled cord is extremely difficult to replace (it's actually less expensive to replace the entire set of headphones of you can get a good discount).
    POSITIVES:
    1) AUDIO FIDELITY. Unless you want to spend at least $300 for a set of headphones, the sound quality and fidelity of the Pro-4AA's is almost impossible to beat.
    2) VALUE. As noted above, for the price you pay, these are vastly superior to any other headphones that are comparably priced.
    3) DURABLE. My first pair lasted 30 years. They were dropped and knocked around, and finally gave out when (It think) a voltage spike surged in the left earphone, fusing a coil.
    4) ISOLATION. THe paddded earphones block out external sound very well.
    afterburnt wrote: »
    I have a big head -- in more ways than one (of course).
  • Dabutcher
    Dabutcher Posts: 2,606
    Audio Technica ATH M50. Catch the right sale. $100.00. They are amazing for the price point. Good luck. D
  • rooftop59
    Dabutcher wrote: »
    Agreed that at that price point they are very good, but as with all things audio, stretch your budget a bit and you can do better. The momentums are a LOT better, just wish they were bigger...
    Game Room 5.1.4:
    Bedroom 2.1
    edited August 2016
    M50s can be had at sale prices. They're a nice closed back with a mild V shape sound curve. Somewhat boosted highs and lows, slightly recessed mids, decent sound stage. I own a pair. I also have a pair of the studio Sonys I bought for my daughter who is currently recording a CD with her college acapella group in Rochester, NY., fingers crossed (phenomenal pipes!).
    The Sonys are more neutral than the Audio Technica ATH M50xs if you're looking for that. This also applies to the Sennheiser HD 280s (their studio standards) which have less bass than the Sonys (to my ears).
    The AKG K240s are a semi-open back that do not leak that much. And are also worth a look.
    These cans make up the go to for studio: Sony 7506, AKG K240, Senn. HD 280, Audio Technica ATH M50x(also the lower 40s which are more neutral). Almost all available in your price range. If you have a Guitar Center in your area you might be able to try most of these out?
    There are LOTS and I mean LOTS of other cans in that sweet spot ($100). You should check out innerfidelity.com and Tyll H.'s reviews! And now, where is that "guy" with the Big Head? As if we didn't know! When mine gets too big I go to the gym and watch my students lift what I no longer can-mortality, it's so very humbling! lol
    Post edited by cnh on
  • rooftop59
    Anyone heard these? https://www.amazon.com/dp/B006MA9XXM?psc=1 they look interesting at a r4eally good price...
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    I sent off for a set of 40x for 90 bucks. I can't afford them right now but I have to have them. I got me a new finance and had her move in with me lol.
  • afterburnt
    I also ordered 16 ounces of coyote urine along with the cans
  • rooftop59
    afterburnt wrote: »
    WTF???
    Hope you like the cans and the help with the, uh, situation...
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    I live in the sticks sort of where rodents chew the wires in my car. Those damn things cost me 350 bucks afew weeks ago. Prdator piss is supposed keep em away.
  • afterburnt
    edited August 2016
    I sprayed coyote urine all over my whole system so I am not worried about that. It don't smell so good but it still sounds great.
  • rooftop59
    afterburnt wrote: »
    WOW.
    I also read recently that rats hate the smell of peppermint. So this https://www.amazon.com/dp/B00016QTXA/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=1944687722&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B00028O80I&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=Q1GV5Y73NJ2EWZFT7GE9 might be a better smelling option...
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    edited August 2016
    rooftop59 wrote: »
    afterburnt wrote: »
    WOW.
    Roof of course that was not a serious post they don't get in my house but they do get under the hood of my car. It does not help that I only drive it every other week. Regarding the peppermint, I don't know if it is "peppermint" that I have growing, it's some kind of mint. I have a flower bed full of the stuff. I saw my cats chase a rat out of it once. I guess that rat wasn't all that deterred. This has been an ongoing battle since I moved here. I am back in a canyon in the mountains and my biggest problems are all the damned critters out here, bobcats, raccoons, skunks, rattle snakes etc. Country living sucks! The previous wire bill was $500!
  • rooftop59
    I know I know, pretty funny.
    But seriously, have you smelled fresh mint compared to peppermint soap or spray? Quite different. The smell of fresh mint is very subtle (but excellent muddled in a mojito mmmm...). The smell of that soap is robust, just saying it might be worth a try and help you avoid predator piss lol...
    Game Room 5.1.4:
    Bedroom 2.1
  • Nightfall
    edited August 2016
    Linday Lohan seems to be starting up her own branded cans. Probably trying to compete with Dr. Dre. Here's a side shot. Looks like solid 50mm drivers.
    afterburnt wrote: »
    You can always try DIY
  • voltz
    voltz Posts: 5,384
    nbrowser wrote: »
    I've always thought these were the best sealed cans...until they got unsealed...but what do I know? Oh should cost about a buck or two per can...
    I had a Tomato Soup can that was a AM radio when I was young teen
  • ALL212
    ALL212 Posts: 1,659
    Nightfall wrote: »
    These do not fit the OP's question as they are certainly not sealed!
    Aaron
    Enabler Extraordinaire
    EndersShadow Posts: 17,715
    I'm gonna suggest a set of comfy fun cans. Beyerdynamic DT-770s.
    Easy to drive off a phone, get very loud, can wear them 12 hours straight (with glasses to boot) without sweaty ears or pain from clamp force.
    V shaped sonic sound but for me at work while coding or doing work they are GREAT. Not the best for making sure others don't hear your music but not the worst either.
    Pads can be replaced as well which is quite nice.
  • cfrizz
    cfrizz Posts: 13,415
    The Momentums have had a redesign that is supposed to be more comfortable.
    http://www.cnet.com/products/sennheiser-momentum-2-0/
    msg Posts: 10,452
    V shaped sonic sound - lows and highs bumped?
