WTB: RTA12b hat cloth
Flathead38
Flathead38 Posts: 72
edited August 2016 in Wanted (WTB) Classifieds
Just purchased a pair of 12b's and I need to get cloth for one. I have the frames, one has been recovered and not well, it is also too transparent. Looking for original if any one is parting one out. Thanks
  • codycatalist
    codycatalist Posts: 2,661
    I believe they used the same cloth as the grills. Chances are you will not find an original cloth set, I've read that there are great after market alternatives that are even better than what was used originally. Do a quick search on grill cloth and i'm sure some suggestions will come up.
    Best of luck!
  • codycatalist
  • Flathead38
    I understand that there are cloth alternatives, but the originals are sewn together. The one that I have that was repaired is stretched and stapled and just does not match.
  • drumminman
    drumminman Posts: 3,396
    I have 1 or two hats I can sell that have good original cloth.
  • Flathead38
    Interested. Pm'd you.
  • drumminman
    Not sure how to check pm's on an iPhone. I'll take pics and send them to you tonight or tomorrow.
  • Flathead38
    edited August 2016
  • drumminman
    Check your PM.
  • Flathead38
    edited August 2016
    Sorry, missed my messages
  • Flathead38
    Thank you for the pics. As I go over the pictures, I see several differences between your two and the ones I have. I am going to keep looking for a closer match. Again thanks for the time and effort.
  • drumminman
    Differences yes. That's what I was describing in the pm. Intact hats are tough to find - good luck!
  • Flathead38
    I appreciate what you were trying to say about the mounting being different, but even the way the cloth is applied is different. Mine do not have cloth on the back, they are wood and the cloth is not stapled, it is held by a plastic roping in a groove similar to the way a screen is installed in a frame.
    Again thanks.
