Good Budget Speaker Wire and ICs?
Nice! I wish I could get nice things too.
Just kidding I count my blessings!Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
^I dislike you right now Skip lol"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Does the "16" mean 16 ga? If so Is that available unterminated/bulk?Helicon is in. No listening yet.
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
any cables will make a diff over none! LOL!...cables that will... ...make a difference.
Look light enough for tweeters - I'm interested. Per foot $?Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
OFC = O2 free copper
OCC = ???
Email sentSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
OCC = ???
Email sent
This mighta help
The highest-quality technique for drawing copper is called “Ohno Continuous Casting” or OCC. OCC copper has one grain in about 700 feet—far less than even LC copper. The audio signal travels through a continuous conductor instead of traversing grain boundaries. Because OCC is a process that can be performed on any purity of copper, not all OCC copper is equal.2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
On my 2.3TLs would it make sense to use the Helicon 16 from the x-overs to the drivers and tweeters but use a heavier gauge like the Supra Rondo 13 awg from the binding posts to the x-overs? Or just use the Helicon 16 for both?Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I'd go heavier BP to XO - 10 ga but no smaller than 12 ga. I think even 12 ga "leave performance on the table."
The cheap AR 12 ga I used(from PE) from BP to XO to the mid/woofers soldered all the way "warmed up." my center channel considerably.
My next "time under the hood" I'm upgrading w/10 ga from Bluejeans.
TonySamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
Everyones definition of "budget" varies, but in what may be on the upper edge of budget as I understand it, would be Kimber PBJ and 4TC. The added value here is that these are cables that could easily grow into practically any upgrade in the future.
Just my 2 cents.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
*sigh* In my 36 years in this hobby gage DOES make a difference, inside and out. I've preached that almost dogmatically my ten years on this forum.I highly doubt the gauge is going to make any difference in such a short run... ...You won't be losing power.
Every pair I've done, I listen* after doing one speaker. Except for my 'A1s, every time the modded speaker is louder, than the stocker.
go big, 2X, 3X or go home.For a subwoofer, I don't think I would advise the helicon series or a smaller gauge...
The first pair I rewired, 36 years ago I used MC 12 ga & "tested*" them w/an NAD 45WPC integrated amp at a moderate volume. As I "beat the dead horse," the modded was louder....but you aren't sending hundred of watts to a single driver in this case.
We can't do anything about the XO's cap leads, etc. but we can go bigger everywhere else. Your RTi A series a little thin even w/an amp, get busy inside before you shop for a "warmer" amp.
You can hear a diff w/boutique cables, I'm certain you'll hear this waaay cheaper "upgrade" too.Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
