1.2TL vs 2.3 TL in a smaller room
  • gmcman
    gmcman Posts: 1,859
    gmcman wrote: »
    I received a few pics, looks to be blade/blade so that would make them a SRS not a 1.2. Not sure what a good price is for them, since they would need 8 mid range drivers and 8 tweeters to bring them to a TL.
    Oh the rabbit hole.
    You cannot "TL" an original SRS. It's 2nd/3rd Generation, and requires a Common Ground Amp.
    They're expensive to upgrade properly, but will sound amazing and will hold their own against the 1.2 and 1.2tl.
    If your heart-set on 1.2tls, wait until a pair comes up within a reasonable distance.
    Ok, I see
    I'm not doubting you, just trying to learn how these big SDA's work. Common ground amps would be pretty much most modern stereo amps correct? I thought this problem comes into play with mono block amps only or some old vintage amps.
    I was thinking ( while the expensive option) that the SRS with new boards, inductors, caps, etc, 8 MW 6511, and 8 RDO 198 could be transformed into a TL version.
    Again that wouldn't be cost effective unless I could find them at a bargain basement price IF it could even work but seems that's not the case.
    I agree it's best to wait for a 1.2 or 1.2TL if I wanted that version....I guess I'm getting ahead of the game.... :smile:
    F1nut Posts: 51,996
    No, many current stereo amps are non-common ground dual mono.
  • gmcman
    gmcman Posts: 1,859
    I double checked my B&K amp with my Fluke and with the setting on 500 ohms I ended up with .17 ohms across the negative speaker terminals.
  • gmcman
    gmcman Posts: 1,859
    Looks like this is coming together....will post pics after a road trip, likely tomorrow.... ;)
    F1nut Posts: 51,996
    Somebody is a happy Polkie tonight. Congrats!
  • gmcman
    gmcman Posts: 1,859
    Yes....thanks.
    14 hrs later....glad to be home as well.... :o
  • Nightfall
    Nightfall Posts: 10,083
    That's not so bad, I drove 26 hours for mine ;)
    Getting home does feel great, lets see some pics tomorrow.
    afterburnt wrote: »
    Village Idiot of Club Polk
    F1nut Posts: 51,996
    Ha, I thought you were home earlier when you texted me. Bet you'll sleep well.
  • lightman1
    lightman1 Posts: 10,797
    He sounded a little jacked up when I spoke with him. Pill poppin truck driver, I'd suspect.
  • gmcman
    gmcman Posts: 1,859
    26...ouch....but I will say after hearing them I can see why...and they're in their modding infancy.
    F1...I was about 2 hrs into the return trip, wish I was home for sure. My super trooper 7YO stuck it out until about 10 pm....he wasn't having anything to do with me leaving for some big speakers and him staying home. Now I just need to wait until sunrise to finally settle down to keep that shift work sleep schedule going. Then.....yes, I will be in some deep sleep... ;)
    Would like to get the sides redone, has a few snags here and there but nothing too serious.
  • gmcman
    gmcman Posts: 1,859
    lightman1 wrote: »
    Lol....That was the 20OZ of some fine coffee kicking in.
    F1nut Posts: 51,996
    Did the super trooper help carry them?
  • gmcman
    gmcman Posts: 1,859
    edited August 2016
    No, but he helped with the blankets...lol.
    Staying in the van till morning, best I can do right now, sorry about the glare.
    F1nut Posts: 51,996
    edited August 2016
    That counts. B)
  • motorstereo
    motorstereo Posts: 2,364
    Congrats to you! I'm betting you're going to love those 2.3s.
    I did a 24 hour round trip for my 1.2s so I have a good idea of how you feel after that long journey.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    Congrats on your new 2.3TL's !!!
  • gmcman
    gmcman Posts: 1,859
    Thanks, been looking for awhile for one of these larger SDA's and it was boiling down to how many hours was I willing to drive...but I agree, I think it's going to be well worth it.
    First off, I looked for the air leaks. A few of the screws for the dimensional drivers were loose, some 1 full turn out so with all the screws snugged down, the push-test is much better and more even balanced between the two, but not perfect......a solid 3 count between both of them so I will work on that.
    Now, for those that have taken a stock 2.3 TL into a fully modded version, did you notice any veiling in the, I want to guess, 1K-3K Hz range? Granted these have the RDO-198 tweeters but stock crossovers with the poly switch jumped. I'm also trying to compare them to a fully modded and well broken in 2B-TL.
    I set them up, grills off, used existing gear as I did for the 2B's, but I noticed a void in that frequency range, almost like a tweeter wasn't connected but all are working. So I swapped the B&K Ref 50 pre-amp which is known to be slightly on the "warm" side to my trusty Yamaha CX-1000 and low and behold, everything was cleaner, even the freq range in question. I love the Ref 50, but it seems there is just this void somewhere and I can't put my finger on it. The vocals aren't bushed back, just ever slightly attenuated along with some upper mid range and could be the result of worn caps. I noticed this with the 2B's but it's very slight with them....hard to say.
    Now this could be that the Yamaha is just bright but is this the common issue with old crossover components with the 2.3? Has anyone had similar first impressions and then a fresh crossover clear everything up? I've only compared my 2B to a stock speaker to a modded 2B so I can't say how the 2.3's behave.
    When I started with the 2B, the difference wasn't as dramatic, but the highs just got smoother...like butter smooth so I'm curious if something is out of whack, or maybe these 2.3's are telling me I need a better pre-amp.
    The sound from the 2.3's is much fuller than the 2B. Don't get me wrong, my 2B's are very detailed, great sound stage, and I don't think I can part with them....but right off the bat I can see how these 2.3's just effortlessly fill the room. The midrange/midbass is much more pronounced than the 2B, I didn't think they would sound like this, can't wait to get them dialed in.
    Flash was a little hot. The base could use some TLC as well as the side panels but that's something I can take care of down the road.
    Left speaker
  • vmaxer
    vmaxer Posts: 5,121
    Nice, enjoy.
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
