Sansui AU-9500 Integrated Amp. 1970's vintage in very good condition.
Time to thin the herd.
Sansui AU-9500 integrated amp from the mid 1970's. Only issue I've found is I've had to put a small piece of electrical tape over the power cord in one place. There are some small scratches on the top of the faceplate in the aluminum and some pitting but this is a very presentable piece. Three speaker outputs (only two can be driven at the same time) with an output of 75w/channel. This is old school rating so you're getting real power at each speaker. Triple tone controls with three frequency settings and level for each. More switches than you'll ever figure out and more inputs and outputs than most mortals can handle. Adjustable tape and aux input levels. Phono 2 has three impedance settings. Original jumper between pre and power (yes, you can run this as just a preamp or just a power amp). Original shorting RCA's (1 pair). Power cord and cord retainer are also original. All controls work. There are no known issues other than the small tape on the electrical cord.
http://sansui.us/AU-9500.htm for more information and
http://sansui.us/PGMP_AU9500.htm for pictures (not this unit)
Also comes with the original brochure and Operating and Service Manual.
Asking $650. This does NOT include shipping which will run somewhere between $75 and $100 to include proper packing. Total cost could be as high as $750 shipped.
The sticker does say 220v but the jumpers are set to 120v and it has a standard two prong USA power connector. I've been using this for a number of years so it's set correctly.
If you have questions or would like more pictures just ask.
Aaron
Enabler Extraordinaire
  • lightman1
    lightman1 Posts: 10,797
    No bluetooth!!!??? No sale!
    One of the most versatile pieces Sansui ever built. She's a beauty, fer sher.
    Good luck.
  • codycatalist
    codycatalist Posts: 2,661
    Lots of features, I like the adjustable output levels on the back. Nice piece! GLWTS!
  • ALL212
    ALL212 Posts: 1,664
    Bump - I'll bump again Friday and then off to the 'bay.
    Aaron
  • ALL212
    ALL212 Posts: 1,664
    Last Bump - next stop is the 'bay
    Aaron
