Christmas in July...
Joey_V
Well well well, Mr. UPS man... What did you bring me today??
(Btw I really like the packing job this seller did, even covered up the brand on the box! Nearly incognito...)
A new watch?Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
LolMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
I think the real winners here are the "Do Not Drop & Fragile Stickers".
PFB.....are you taking pointers.....
How long before the piano movers arrive to carry box upstairs?
Do you call them for YOURSELF as well?
"Darling, you'll have to put the caviar in the fridge. The Joey-movers are running late and I don't do stairs....."
Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
How heavy can a box of shorts be?Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
The creatures outside looked from pig to man, and from man to pig, and from pig to man again; but already it was impossible to say which was which.”……George Orwell-Animal Farm. -
Low blow!!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
I also received a rather large and heavy box today. I opened it excitedly and found rocks inside. Then, I remembered I bought 50lbs of rock salt and it must be it.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
HahahahahahaI also received a rather large and heavy box today. I opened it excitedly and found rocks inside. Then, I remembered I bought 50lbs of rock salt and it must be it.
Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I got so busy today I have yet to open it... Hoping it's good!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
culd it be large cables w/ a small bend radius?
Here ya go!
Perfect packing... Could not be happier!
congrats, get your name added to the client list.
Sweetness
Not perfect packing...I see no packing peanuts anywhere!
Grats on the new acquisition bro.
Thanks broman... I am glad I bought it. A little sacrifice, yields good results.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
quite a setup! lookin good warrior!
real good.
I just reading up on their CD transport /stereo DAC
last night.
http://www.dagogo.com/emm-labs-tx2-limited-edition-cdsacd-transport-da2-stereo-dac-review
Post edited by [Deleted User] on -
rednedtugent wrote: »quite a setup! lookin good warrior!
real good.
last night.
Yeah, it's too bad I couldn't swing the new next gen Emm... freaking 25K x2.
I'll just slum it up with the Dac2x and TSDX... hahMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Right now, I can tell you, if this is the limits of my system with the Emm Dac2x. I am perfectly fine with that. I am nearly 100% satisfied.
And I could not say that months ago.
It is just simply a superb system. Far better than when I had the BW 802D2, the Sonus Faber Stradivari, or even the Rockport Avior in my system. It is simply my sound.
Just a wee bit more palpable imaging, just a wee bit better room control and I think I'm at retirement.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
So what speakers are you currently running now?2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
txcoastal1 wrote: »So what speakers are you currently running now?
I think someone went and bought the D3's
2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Lies.... Lies!!!!Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Congrats Joey! Glad that you got a shiny toys! Sadly all I got was rock salt. But then, I only got what I paid for.
Anyway, those Russian Tung Sol 6SN7s need to go! You'll make an equal improvements like that EMM DAC for minimal investment with different set of tubes in the SLP05.Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
2 channel:
Theater:
Gotta say... As I get to know the Emm Dac2x (half the stack), it is such a nice upgrade. As good as the Cary 306 SACD was, it just can't compete with the air around instruments, the micro details, palpability and roundness to the instruments.
Easiest to explain... Listening to The Weeknd, track 12: Dark Times.
Cary just doesn't capture the soundstage depth... It's so easy to hear the rear of the stage, it sounds more voluminous and 3D on the Emm. The bass and all instruments sound better. The voice is pulled forward and more palpable.
Two thumbs up. No regrets and no remorse.Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
Sounds great Joey! Enjoy.
If your ready for another set of speakers
http://www.spatialaudio.us/lumina2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Nope no moreMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
Then Kick back, relax & Enjoy
Congrats Joey! It's nice to have some system synergy going on!2 channel:
Theater:
Emm + Cary + BoulderMagico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R
