better or best-Adcom pre/am or NAD 1020a or 1020b
leftwinger57
in Electronics
Finding myself home again w/ the itch of wanting a vintage pre amp i kinda settled on an Adcom model not readily known or my love affair w/ the NAD 1020a pre which was very responsive and did what I needed sans a remote. Cruising E-Bay I noticed a NAD 1020b pre which I never heard of. Any of you out there w/ any experience w/ the B model and how much better could it really be above the A model if at all. Yes I know it also has no remote but if you guys could suggest something in this price range and quality I would be really greatful..
http://www.ebay.com/itm/Vintage-Nad-1020B-Stereo-Preamplifier-W-Original-Box-/331907179851?hash=item4d4735a54b:g:jOUAAOSww9VXhW4d
You can snag a B&k AV30 pre amp for about 150 bucks. They all come with a remote, connections up the ying yang, and good quality dacs built in.HT SYSTEM-
lsi 9's -
The Carver pre's are fun in the right room w/ the right set-up.
Unfortunately, they have a lot of fan$.
I liked the NAD sound but I'm not sure I'd go that way today.
What amp to pair w/? -
I believe the differences between the A and B models were in the phono stage, and the location of the mm/mc switch.
My 1020 was completely torn apart, recapped, cleaned, and the back panel jacked removed and resoldered. Before restoration, it was a tad muddy and noisy. Now paired with the DNA 0.5, I think I would hard pessed to replace it without spending significant coin, or moving to tubes.
I bought mine 25 years ago, and the refresh was $175, and to my ears, some of the best audio money I have spent.Polk Lsi9
N.E.W. A-20 class A 20W
Keces DA-131 mk.II
Paradigm DSP-3100 v.2 -
Besides what has been mentioned, I am going to throw the Adcom GFP565, Integra p304 or p308, and Kenwood Basic C2 into the ringKlipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I think I had a lead on a Parasound P-5 I think(not sure of model #) going for $200 from the Klipsch Garage Sale Site a ways back when I had no funds but 2 bills for a unit that did everything plus the remote is a great deal. The Adcoms I do not want a tuner built in at all in any unit and if not going w/ the NAD it must have a remote. I'll still wait and using Heiny's logic do your research as if your life depended upon it and it was your last piece you were going to get. Never a truer a word ever spoken !!!
Thanks for the help and when money is in hand I will and this is a promise to let you dudes know where to steer me...Lew
http://www.audioholics.com/av-preamp-processor-reviews/parasound-halo-p-5-stereo-preamplifier2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Sorry, I always forget something. I did have an Onkyo P-301. It had all the inputs you could use and I found it's achilles heel was the amplifier output ports would give way and make for a bad connection or throw a channel out right. The P-3150v a more updated version was ok and those motorized volume pots mesmerized me to no end like looking at McIntosh meters of the 2105s or Jerry's 2300s What can I say, it's the simple things in life that turn me on,to be polite......2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
Haven't heard the NAD, have heard the adcoms (about 1/2 dozen of them) take the NAD.Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I have one of these, the DAC is awesome.B&W CM9Classé Sigma -
200 for a p5 is a bargain!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
