better or best-Adcom pre/am or NAD 1020a or 1020b
Finding myself home again w/ the itch of wanting a vintage pre amp i kinda settled on an Adcom model not readily known or my love affair w/ the NAD 1020a pre which was very responsive and did what I needed sans a remote. Cruising E-Bay I noticed a NAD 1020b pre which I never heard of. Any of you out there w/ any experience w/ the B model and how much better could it really be above the A model if at all. Yes I know it also has no remote but if you guys could suggest something in this price range and quality I would be really greatful..
http://www.ebay.com/itm/Vintage-Nad-1020B-Stereo-Preamplifier-W-Original-Box-/331907179851?hash=item4d4735a54b:g:jOUAAOSww9VXhW4d
    tonyb Posts: 33,065
    You can snag a B&k AV30 pre amp for about 150 bucks. They all come with a remote, connections up the ying yang, and good quality dacs built in.
  • [Deleted User]
    [Deleted User] Posts: 10,716
    edited July 2016
    The Carver pre's are fun in the right room w/ the right set-up.
    Unfortunately, they have a lot of fan$.
    I liked the NAD sound but I'm not sure I'd go that way today.
    What amp to pair w/?
  • 11tsteve
    11tsteve Posts: 1,166
    I believe the differences between the A and B models were in the phono stage, and the location of the mm/mc switch.
    My 1020 was completely torn apart, recapped, cleaned, and the back panel jacked removed and resoldered. Before restoration, it was a tad muddy and noisy. Now paired with the DNA 0.5, I think I would hard pessed to replace it without spending significant coin, or moving to tubes.
    I bought mine 25 years ago, and the refresh was $175, and to my ears, some of the best audio money I have spent.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
  • erniejade
    erniejade Posts: 6,321
    Besides what has been mentioned, I am going to throw the Adcom GFP565, Integra p304 or p308, and Kenwood Basic C2 into the ring
  • leftwinger57
    leftwinger57 Posts: 2,917
    I think I had a lead on a Parasound P-5 I think(not sure of model #) going for $200 from the Klipsch Garage Sale Site a ways back when I had no funds but 2 bills for a unit that did everything plus the remote is a great deal. The Adcoms I do not want a tuner built in at all in any unit and if not going w/ the NAD it must have a remote. I'll still wait and using Heiny's logic do your research as if your life depended upon it and it was your last piece you were going to get. Never a truer a word ever spoken !!!
    Thanks for the help and when money is in hand I will and this is a promise to let you dudes know where to steer me...Lew
    http://www.audioholics.com/av-preamp-processor-reviews/parasound-halo-p-5-stereo-preamplifier
  • leftwinger57
    Sorry, I always forget something. I did have an Onkyo P-301. It had all the inputs you could use and I found it's achilles heel was the amplifier output ports would give way and make for a bad connection or throw a channel out right. The P-3150v a more updated version was ok and those motorized volume pots mesmerized me to no end like looking at McIntosh meters of the 2105s or Jerry's 2300s What can I say, it's the simple things in life that turn me on,to be polite......
  • soundfreak1
    soundfreak1 Posts: 3,414
    Haven't heard the NAD, have heard the adcoms (about 1/2 dozen of them) take the NAD.
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • RamZet
    RamZet Posts: 792
    tonyb wrote: »
    I have one of these, the DAC is awesome.
    B&W CM9Classé Sigma
  • erniejade
    200 for a p5 is a bargain!
  • JPete
    JPete Posts: 295
    erniejade wrote: »
    Yes, yes it is.
    Lexicon RT-10, Parasound P5, McCormack DNA 0.5, Polk SDA CRS+, SVS Sub
    Schiit Modi, Luminous Audio Axiom II, McCormack DNA-1, Digital Phase AP 2
    Marantz AV7701, Emotiva XPA-5, Paradigm 11se Mkii, DCM Time Windows, NHT 2C, SVS Sub
    Spares - Kenwood C1 Pre, NAD 2200PE, Polk Monitor 10B, Polk Model 11, other odds and ends
