A Job For Lightman
SCompRacer
When you change your lights, who ya gonna call?
Folks say if you are dealing with gas discharge lamps, call Lightman.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
Ready and able, Rich and Skip!!!!
I am adding OEM Xenon HID headlights. It's a little harder than hanging an air freshener on the mirror....lol Wiring isn't too complicated. The HID relay exists in fuse box underhood, but the Body Control Module will need a wire added along with some programming, extra wires to headlight capsules. Same BCM in HID and non-HID vehicle. Fred will figure out the issues in seconds. Who else will? It involves DRL.....daytime running lights...
Halogen.....presently equipped....
HID.....same bulb for low and high beam, low beam has shutter that blocks half the light. High beam, shutter opens.
HID DRL...separate bulb....
Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
It's a bird, it's a plane, no, it's a 500,000 volt electrical arc Lightman1!
https://www.youtube.com/watch?v=6GiIVze2Tac
Having lunch with the Irish Latin scholar from Cornell today. I know you're all jealous!Currently orbiting Bowie's Blackstar.!
There's only 1 right way to do something and knowing Rich, he only does it the right way! It makes a huge difference."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul!
SComp, at least it appears your changing the light housings to projector style, a big plus if converting to HID. Too many cars I see on the road and in my shop have had cheap conversions done with existing housings and the HID bulbs are more glaring and so very ineffective at night. Good on you for doing it right!
You know it! If you don't have the shutter blocking the top half of beam, there is no 180 degree top cutoff and you blind oncoming drivers. I do have projector Halogen but the HID are so much better.
It's a pricey upgrade going OEM, but some good deals and nice LKQ parts keep it reasonable. Factory list is $1300 per capsule! I snagged a new left for $225, LKQ right for $275. Underhood harness $125 my cost. Proper terminals for BCM and underhood harness connectors a few bucks each. Even have the proper Brown/Yellow trace wire on the way.
Do you do any GM programming at your shop? The dealer will nick me $140, one hour, to program BCM (Body Control Module). Some dealers won't program beyond factory equipped. I could send the BCM to the guy that programmed my nav radio, but would lose use of the car until I got it back. We must embrace that darn GM Global A Electrical Architecture Security.
With Halogen, low beam is the DRL. The BCM uses PWM (Pulse Width Modulation) to reduce voltage for DRL (Daytime Running Lights). Terminals F9DA and F23DA. When headlights are turned on, PWM ceases and BCM supplies B+ to low beam. High beam is second bulb.
WIth HID, DRL is separate bulb. BCM sends B+ out of same terminals F9DA and F23DA (same as for halogen low beam) but must shut off when headlights turned on. BCM terminal X5 pin 13 must ground HID relay to power headlights.
I try and do right Brock! lol
That ark looks like lightman's beard!
I'll like the Blacked out look of the HID capsules too.
That's a good looking Chevy!Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
Thanks! 2015 'Bu, LTZ with 1LTZ, Silver Ice Metallic. OEM rear camera and OEM nav added. Focal component front, coaxial rear, 5 channel amp and sub. Chemical Guys dot com for the supplies and me the labor.
Bought it at one year old, low miles. Clay blocked entire car and glass, light machine polish to get the car wash swirls out, Chem Guys JetSeal and their 5050 Carnauba wax. Carnauba really makes em pop compared to full synthetic waxes. 3M Crystalline tint, 35% max legal here on sides and rear.
I need do something like that to protect the paint on my new Colorado. I have already been getting scratches behind the door handles from my wife's rings.Oh, Listen here mister. We got no way of understandin' this world. But we got as much sense of this bird flyin in the sky. Now there is a lot that bird don't know, but it don't change the fact that the world is happening to him all the same. What I am tryin to say is, is that the course of your life, well its changing, and you don't even see it- Forest Bondurant
3M makes a clear protector mask that could be used for that cause wax or sealers won't help much with that. Check with a tint shop. They use that clear mask for the invisible bras on the front bumper covers.
A good friend turned me on to the Chemical Guys. Great products. Easy to spend money there.
http://www.chemicalguys.com/Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
jeremymarcinko wrote: »I need do something like that to protect the paint on my new Colorado. I have already been getting scratches behind the door handles from my wife's rings.
If you opened the door for her like a gentleman you would't have that problem. -
Unfortunately we don't program computers ourselves as we are an all makes/all models shop the cost for the occasional re-program of factory systems would be cost prohibitive equipment and software wise. We do have a guy though who is into complete electronic diagnosis and re-programming. It's his special interest so he's invested in the hardware, software and training on how to do it right, he's the first call if we need that odd and rare programming done.
I hear you. The gear is expensive enough but them subscriptions are costly. The only factory access programming we have here for the fleet is for the Mercedes Sprinter and Isuzu. We only have a few GM vans, so no GM programming.
I was looking into that GM MDI interface and a laptop. Pricey for personal use though. I was told you can't get all the programming software needed with a three day subscription if you supply the laptop.
Authentic Tech 2's are pricey and the Chinese knock offs are cheap, look good but don't function properly. A buddy bought one and he couldn't get it to cycle an ABS motor.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Although polar opposites even his uncle was highly qualified in the field..
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
And don't mess with @lightman1 ... he will put 60 Hertz on you!My New Year's resolution is 3840 × 2160
2 Times!Mikey081057 wrote: »And don't mess with @lightman1 ... he will put 60 Hertz on you!
Hahaha.....I got a "job" for Lightman!
His new pic
Or is he a relative of the West Virginia Wallace's known to inbreed with ferracity .
Sincerely hope our friend @lightman1 and others are safe tonite in Carolinas as storms are moving through...
Eh, these are just simple Southern afternoon storms. Nothing to worry about in my neck of the woods. Although I will say this.....the lower clouds sure did have a "weird" look to them today. That's about the only thing that's different. Grilling out as we speak...
Shut up Russ. You Putz.
Got 'em installed Saturday! No more work for lightman, just get here and drink beer, burn stuff on the grill now!
Maybe Russ can help Rich find out where all the left over parts go2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
In the drawer with the rest from other projects. -
I just drink another Fat Tire and forget about it! lolSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
