Tubes Mostly Preamp & Power Tubes
snow
For sale are a few tubes. As always your happiness is guaranteed 100% or your money back. All tubes have been tested and test above minimum good pictures and test results of any tube/s upon request. These tubes unless noted other wise are used some may be dirty and or missing print. Please allow up to 3 days for me to pack and ship your tubes it may well be sooner.
Amperex-12AX7-Gray Plate Halo getter Halo getter-1-$20.00
Mullard Made GE labeled Grey plate Halo getter 12AX7A-1-$20.00
Mullard Made RCA labeled Grey plate Halo getter 12AX7-2-$20.00 veach
Telefunken long grey ribbed plate 12AX7-2-$30.00 each
RCA Short Grey plate 12AX7A-2-$7.50 each
RCA short grey plate Halo getter 7025/12AX7-1-$20.00
Webcor labeled RCA made 12AX7-D getter Long Black plates-1-$30.00
RCA Black plate 7025 D getter-1-$40.00
Sylvania 12AX7 short grey plates Halo getter-1-$7.50
GE-6680/12AX7-Grey plate Halo geter-1-$25.00
GE JAN 12AX7 long grey plate Halo getter-2-$7.50 each
GE long grey plate 12AX7 Horse shoe getter-1-$10.00
GE 5751/12AX7 short grey plate halo getter-1-$10.00
GE 5751/12AX7 triple Mica grey plate halo getter-1-$25.00
GE 5751/12AX7 triple Mica grey plate Horseshoe getter-1-$25.00
GE 5751/12AX7 JAN- short grey plate halo getter-18-$10.00 each
Sylvania 5751 12AX7 short grey plate halo getter-1-$10.00
Sylvania 5751 12AX7 JAN-short grey plate halo getter-15-$10.00 each
GE 12AY7 short grey plate D Getter-2-$30.00 each
CBS-12AZ7-Short Black plates halo getter-1-$20.00
Amperex 6DJ8 halo getter-1-$20.00
Amperex PQ-6922/6DJ8- Gold pins-1-$65.00
GE 6DJ8 halo getter-NOS-1-$10.00
Sylvania 12AT7WC-grey plates halo getter-1-$5.00
Sylvania JHS-12AT7-3 Mica grey plates-D-getter-2-$30.00 each
Sylvania JHS-12AT7-3 Mica Black plates-D-getter-1-$35.00
Webcor 12AT7 Black plates D-getter-1-$20.00
GE 6201/12AT7 grey plates halo getter-4-$7.50 each
RCA-12AU7A Clear Top-Side D getter-2-$10.00 each
RCA-12AU7 Long grey plate D getter-1-$20.00
Sylvania-6189W/12AU7-3-$7.50 each
GE-6189/12AU7-1-$7.50
Sylvania-6679/12AU7 Black plates-1-$20.00
CBS-JHY-5814A- Black plate NOS-2-$125.00 for the pair
Tung-Sol-5687 bronze plate-1-$20.00
GE-5687 Black plate-1-$20.00
RCA-5691/6SL7-2-$100.00 for the pair
RCA 5693/6SJ7-4-$125.00 for the quad
GE-7199 grey plates halo getter-2-$15.00 each
RCA Labeled Amperex Made 5847/404A Tubes Sleeve Of 5 NOS-$65.00 For the sleeve
Amperex PQ- 5847/404A Tubes-3 NOS-$25.00 for all 3
RCA Grey plate 6973-2-$40.00 each
Raytheon Black plate 6973-2-$40.00 each
GE-7189A/6BQ5- gray plates halo getter-2-$15.00 each
Sylvania made Peavey STR-347 labeled 6L6GC Grey plate Disc gtter-2-$20.00 each
RCA 6L6GC-1- Black plate Double D bottom getter- Guide pin is broken off-$20.00
Sylvania 7027/6L6GC-2-$20.00 each
JJ EL34-4-I think these are new tubes but no original boxes-$10.00 each
Sylvania EL34-1- Fat bottle double disc getter the guide pin is broken off-$10.00-
Mullard/Amperex? I think, no code and print is all gone EL34 Double O getter-1-$50.00
Ken-Rad JAN-CKR-2A3 VT-95 Black Glass Dual Mono Plate Tube Pair 1944 NOS-$450.00 For the pair
RCA-2A3- BLACK PLATE-NOS-1945-1-$100.00
Mullard Made Amperex Bugle Boy labeled 5AR4/GZ34 Rectifer Tube-1-$100.00
Regards Snow
Regards Snow
Well, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
I'll take the following:
Amperex PQ 6922 gold pins $65
RCA 6L6GC BP Double D bottom getter $20.00
Thanks.
I'd like these. Telefunken long grey ribbed plate 12AX7-2-$30.00 eachDynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
I'll take both of these: Mullard Made RCA labeled Grey plate Halo getter 12AX7-2-$20.00 veach
PM on Amperex 6DJ8 halo getter also.
PM coming
Thanks everyone PM's sent. Here is a few more new ones
GE 12AU7 long grey plates Halogetter-1-$7.50
Hytron 12AU7 LongBlack plates D getter-$20.00
Westinghouse 12AU7A Longblack plates D getter-1-$20.00
Sylvania 6189/12AU7 Lpoong grey plates Halo getter-1-$7.50
Mullard 12AU7 short grey plates Halo getter-1-$20.00
GE 12AY7-1-$25.00
RCA-7025/12AX7-Shortgrey platesHalo getter-1-$25.00
RCA made Webcor labeled 12AX7 Black plates D getter-$30.00
Mullard 12AT7 Grey plates Halo getter-2-$20.00 each
Packard Bell triple mica Short grey plates D getter-$25.00
Regards SnowWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
Hate to be a pain but do you have some pics of the Hytron 12AU7? I'll probably take it as long as it's not a relabeled RCA. Just want to compare the structure and getter to a couple I already have. They are somewhat hard to come by.
Thanks in advance.
Here you go, it might well be a RCA tube it has the stop sign type emblem but other companies used it also. Very nice tube regardless it was made in 1952 and test at 3600/3500 where 1560 is minimum goodHate to be a pain but do you have some pics of the Hytron 12AU7? I'll probably take it as long as it's not a relabeled RCA. Just want to compare the structure and getter to a couple I already have. They are somewhat hard to come by.
Thanks in advance.
Regards Snow
I'll take it if Heiney passes. I don't care if its a RCA
I'll take it, it's hard to tell for sure, but I'm betting based on the position of the getter. My other CBS tubes have a very slight taper at each end of the plates. This doesn't appear to have that. So it could also be a Sylvania or Raytheon. Although the white print Hytron and the 1952 date strongly indicate it is a CBS tube. Most of the rebranded tubes have red or orange print, not always........but most times.
Let me know the total.
P.s. Don I have plenty of RCA's if you need them. If this turns out not to be a CBS manufactured tube I will give you dibs at the same $$. I have 3 CBS black plate 12AU7's and I need a 4th to make a quad."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Hi Brock upon looking at some more tubes it appears I have 2 of these with the same date the 2nd tube tests at 3300/3400 do you want it also or should I sell it to Don?
Regar
ds DanWell, I just pulled off the impossible by doing a double-blind comparison all by myself, purely by virtue of the fact that I completely and stupidly forgot what I did last. I guess that getting old does have its advantages after all
I want to compare to a few bp's I have at home tonight. So yes, I want them but I need to be sure they are what I'm looking for. If not, then Don can have them.
The getter being attached at the corner and the non-taper plates has me questioning if they are the same as the others I have. I'm at work and don't have the tubes here with me.
Do you mind sitting tight until later this evening. I'll take both if the construction matches the others I have at home.
P.s. I had a mental picture when I came to work of the ones at home, but now I'm doubting a bit."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
Excellent detail on the photo's. It really helps show the construction.
No hurry I can waitI want to compare to a few bp's I have at home tonight. So yes, I want them but I need to be sure they are what I'm looking for. If not, then Don can have them.
Regards Snow
Thanks Dan
I'm going to pass, not the construction I'm trying match.
I'll take the Hytrons. Thanks
I'll take RCA Short Grey plate 12AX7A-2-$7.50 each and the RCA short grey plate Halo getter 7025/12AX7-1-$20.00
Thanks, Phil -
Received the tubes today. They arrived quick and were well packed. I just put them in my modded JD-9 phono stage and they sound great! Thanks Snow!
Great to hear
Received the cbs -jhy 5814a today . Fantastic sound thanks for the recommendation . Worth the price. Nice fast shipping . Thanks again
Great to hear
Arrived safe and sounding Telefunkin fineDynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
Great to hear
What's left in the 12ax7 area?AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
It looks like these are still available.What's left in the 12ax7 area?
Regards Snow
I'll take these if still available:
* Sylvania 5751 12AX7 short grey plate halo getter-1-$10.00
* Sylvania 5751 12AX7 JAN-short grey plate halo getter-15-$10.00 each
Thanks,
CraigBeach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
Received these yesterday in excellent shape. Many thanks for the easy transaction and great deal.
NOTE: I only bought 2 of the JAN 5751's - not all 15. So I imagine these are still available.I'll take these if still available:
Thanks,
Craig
bump to find out what if any
12AU7 tubes are left... -
Hi I have these left.rednedtugent wrote: »bump to find out what if any
1.RCA Cleartop side getter 12AU7A-4-$10.00 Each
2.RCA Long grey plates D getter-1-$20.00
3.Westinghouse 12AU7 Short grey plates halo getter-1-$7.50
4.Mullard 12AU7 Short grey plates Halo getter-$20.00
5.Sylvania 6189W grey plates halo getter-4-$7.50 each
6.GE 6189 Grey plates halo getter-1-$7.50
7.GE 12AU7 Halo getter grey plates 1-$7.50
8.GE 6680 Grey plats hao getter-1-$10.00
Updated partial list of tubes still available some new ones have been added.
1.RCA made Webcor labeled 12AX7 Black plates D getter-$30.00
2.Amperex-12AX7-Gray Plate D getter-1-$40.00
3.Amperex-12AX7-Gray Plate Halo getter-1-$25.00
4.Mullard Made GE labeled Grey plate Halo getter 12AX7A-1-$20.00
5.RCA Short Grey plate 12AX7A-1-$7.50
6.RCA short grey plate Halo getter 7025/12AX7-1-$20.00
7.Webcor labeled RCA made 12AX7-D getter Long Black plates-1-$30.00
8.RCA Black plate 7025 D getter-1-$40.00
9.RCA 7058/12AX7-Grey plate Halo getter-2-$25.00 each
10.Sylvania 12AX7 short grey plates Halo getter-1-$7.50
11.6680/12AX7-Grey plate Halo geter-1-$25.00
12.GE 12AX7 long grey plate Halo getter-1-$7.50
13.GE 12AX7 Short grey plate Halo getter-1-$7.50
14.GE long grey plate 12AX7 Horse shoe getter-1-$10.00
15.GE 5751/12AX7 short grey plate halo getter-1-$10.00
16.GE 5751/12AX7 triple Mica grey plate halo getter-2-$25.00 each
17.GE 5751/12AX7 triple Mica grey plate Horseshoe getter-1-$25.00
18.GE 5751/12AX7 JAN- short grey plate halo getter-18-$10.00 each
19.Sylvania 5751 12AX7 JAN-short grey plate halo getter-15-$10.00 each
20.Sylvania 12AX7 JAN-short grey plate D getter- $25.00
21.Westinghouse 12AX7A Grey plates D getter-4-$20.00 each
22.Raytheon /Lowery labeled 12AX7A- Grey plate Halo getter-6-$7.50 each
23.Packard Bell labeled GE made 12AT7 Triple mica D getter grey plate-1-$20.00
24.RCA 12AT7WA Black Plate triple mica-1-$25.00
25.RCA Black plate D getter-1-$20.00
26. RCA 12AT7 Halo getter Grey plates-4-$7.50 each
27.Sylvania JHS 12AT7WA triple mica grey plate D getter-2-$25.00 each
28.GE 12AT7 Grey plates D getter-1-$15.00
29.GE 6201 Greyplates halo getter-2-$7.50 each
30.GE 6679 Black plates halo getter-1-$10.00
31.GE 6679 GREY PLATES Halo getter-1-$7.50
32.Sylvania 12AT7 WC Black plate Halo geter-1-$10.00
33.Amperex 12AT7 France-1-$25.00
34.Tung-Sol 12AT7 Halo getter Grey plates-1-$7.50
35.Mullard 12AT7 HALO GETTER-2-$25.00 Each
36..RCA Cleartop side getter 12AU7A-4-$10.00 Each
37..RCA Long grey plates D getter-1-$20.00
38.Westinghouse 12AU7 Short grey plates halo getter-1-$7.50
39.Mullard 12AU7 Short grey plates Halo getter-$20.00
40.Sylvania 6189W grey plates halo getter-4-$7.50 each
41.GE 6189 Grey plates halo getter-1-$7.50
42.GE 12AU7 Halo getter grey plates 1-$7.50
43.GE 6680 Grey plats hao getter-1-$10.00
44.Amperex 6DJ8-4-$15.00 Each
45.GE-6DJ8-NOS-2-10.00 Each
