Tubes Mostly Preamp & Power Tubes
snow
snow Posts: 4,358
edited July 2016 in For Sale (FS) Classifieds
For sale are a few tubes. As always your happiness is guaranteed 100% or your money back. All tubes have been tested and test above minimum good pictures and test results of any tube/s upon request. These tubes unless noted other wise are used some may be dirty and or missing print. Please allow up to 3 days for me to pack and ship your tubes it may well be sooner.
Amperex-12AX7-Gray Plate Halo getter Halo getter-1-$20.00
Mullard Made GE labeled Grey plate Halo getter 12AX7A-1-$20.00
Mullard Made RCA labeled Grey plate Halo getter 12AX7-2-$20.00 veach
Telefunken long grey ribbed plate 12AX7-2-$30.00 each
RCA Short Grey plate 12AX7A-2-$7.50 each
RCA short grey plate Halo getter 7025/12AX7-1-$20.00
Webcor labeled RCA made 12AX7-D getter Long Black plates-1-$30.00
RCA Black plate 7025 D getter-1-$40.00
Sylvania 12AX7 short grey plates Halo getter-1-$7.50
GE-6680/12AX7-Grey plate Halo geter-1-$25.00
GE JAN 12AX7 long grey plate Halo getter-2-$7.50 each
GE long grey plate 12AX7 Horse shoe getter-1-$10.00
GE 5751/12AX7 short grey plate halo getter-1-$10.00
GE 5751/12AX7 triple Mica grey plate halo getter-1-$25.00
GE 5751/12AX7 triple Mica grey plate Horseshoe getter-1-$25.00
GE 5751/12AX7 JAN- short grey plate halo getter-18-$10.00 each
Sylvania 5751 12AX7 short grey plate halo getter-1-$10.00
Sylvania 5751 12AX7 JAN-short grey plate halo getter-15-$10.00 each
GE 12AY7 short grey plate D Getter-2-$30.00 each
CBS-12AZ7-Short Black plates halo getter-1-$20.00
Amperex 6DJ8 halo getter-1-$20.00
Amperex PQ-6922/6DJ8- Gold pins-1-$65.00
GE 6DJ8 halo getter-NOS-1-$10.00
Sylvania 12AT7WC-grey plates halo getter-1-$5.00
Sylvania JHS-12AT7-3 Mica grey plates-D-getter-2-$30.00 each
Sylvania JHS-12AT7-3 Mica Black plates-D-getter-1-$35.00
Webcor 12AT7 Black plates D-getter-1-$20.00
GE 6201/12AT7 grey plates halo getter-4-$7.50 each
RCA-12AU7A Clear Top-Side D getter-2-$10.00 each
RCA-12AU7 Long grey plate D getter-1-$20.00
Sylvania-6189W/12AU7-3-$7.50 each
GE-6189/12AU7-1-$7.50
Sylvania-6679/12AU7 Black plates-1-$20.00
CBS-JHY-5814A- Black plate NOS-2-$125.00 for the pair
Tung-Sol-5687 bronze plate-1-$20.00
GE-5687 Black plate-1-$20.00
RCA-5691/6SL7-2-$100.00 for the pair
RCA 5693/6SJ7-4-$125.00 for the quad
GE-7199 grey plates halo getter-2-$15.00 each
RCA Labeled Amperex Made 5847/404A Tubes Sleeve Of 5 NOS-$65.00 For the sleeve
Amperex PQ- 5847/404A Tubes-3 NOS-$25.00 for all 3
RCA Grey plate 6973-2-$40.00 each
Raytheon Black plate 6973-2-$40.00 each
GE-7189A/6BQ5- gray plates halo getter-2-$15.00 each
Sylvania made Peavey STR-347 labeled 6L6GC Grey plate Disc gtter-2-$20.00 each
RCA 6L6GC-1- Black plate Double D bottom getter- Guide pin is broken off-$20.00
Sylvania 7027/6L6GC-2-$20.00 each
JJ EL34-4-I think these are new tubes but no original boxes-$10.00 each
Sylvania EL34-1- Fat bottle double disc getter the guide pin is broken off-$10.00-
Mullard/Amperex? I think, no code and print is all gone EL34 Double O getter-1-$50.00
Ken-Rad JAN-CKR-2A3 VT-95 Black Glass Dual Mono Plate Tube Pair 1944 NOS-$450.00 For the pair
RCA-2A3- BLACK PLATE-NOS-1945-1-$100.00
Mullard Made Amperex Bugle Boy labeled 5AR4/GZ34 Rectifer Tube-1-$100.00
Regards Snow
  • dromunds
    dromunds Posts: 10,140
    I'll take the following:
    Amperex PQ 6922 gold pins $65
    RCA 6L6GC BP Double D bottom getter $20.00
    Thanks.
  • jonicont
    jonicont Posts: 281
    I'd like these. Telefunken long grey ribbed plate 12AX7-2-$30.00 each
    DynaudIo Evoke 30, VPI Prime, Soundsmith Zephyr MKIII, PS audio Stellar phono pre, McCormack DNA 0.5 Gold, ARC LS-17se, Eversolo dmp A8, MIT AVT MA ic’s and speaker cables, ps audio stellar power plant 3
  • Dawgfish
    Dawgfish Posts: 2,554
    I'll take both of these: Mullard Made RCA labeled Grey plate Halo getter 12AX7-2-$20.00 veach
  • dromunds
    PM on Amperex 6DJ8 halo getter also.
  • snow
    snow Posts: 4,358
    Thanks everyone PM's sent. Here is a few more new ones
    GE 12AU7 long grey plates Halogetter-1-$7.50
    Hytron 12AU7 LongBlack plates D getter-$20.00
    Westinghouse 12AU7A Longblack plates D getter-1-$20.00
    Sylvania 6189/12AU7 Lpoong grey plates Halo getter-1-$7.50
    Mullard 12AU7 short grey plates Halo getter-1-$20.00
    GE 12AY7-1-$25.00
    RCA-7025/12AX7-Shortgrey platesHalo getter-1-$25.00
    RCA made Webcor labeled 12AX7 Black plates D getter-$30.00
    Mullard 12AT7 Grey plates Halo getter-2-$20.00 each
    Packard Bell triple mica Short grey plates D getter-$25.00
    Regards Snow
    heiney9 Posts: 25,515
    Hate to be a pain but do you have some pics of the Hytron 12AU7? I'll probably take it as long as it's not a relabeled RCA. Just want to compare the structure and getter to a couple I already have. They are somewhat hard to come by.
    Thanks in advance.
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    Thanks in advance.
    Here you go, it might well be a RCA tube it has the stop sign type emblem but other companies used it also. Very nice tube regardless it was made in 1952 and test at 3600/3500 where 1560 is minimum good :)
    Regards Snow
  • dromunds
    I'll take it if Heiney passes. I don't care if its a RCA
    I'll take it, it's hard to tell for sure, but I'm betting based on the position of the getter. My other CBS tubes have a very slight taper at each end of the plates. This doesn't appear to have that. So it could also be a Sylvania or Raytheon. Although the white print Hytron and the 1952 date strongly indicate it is a CBS tube. Most of the rebranded tubes have red or orange print, not always........but most times.
    Let me know the total.
    P.s. Don I have plenty of RCA's if you need them. If this turns out not to be a CBS manufactured tube I will give you dibs at the same $$. I have 3 CBS black plate 12AU7's and I need a 4th to make a quad.
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    Hi Brock upon looking at some more tubes it appears I have 2 of these with the same date the 2nd tube tests at 3300/3400 do you want it also or should I sell it to Don?
    ds Dan
    I want to compare to a few bp's I have at home tonight. So yes, I want them but I need to be sure they are what I'm looking for. If not, then Don can have them.
    The getter being attached at the corner and the non-taper plates has me questioning if they are the same as the others I have. I'm at work and don't have the tubes here with me.
    Do you mind sitting tight until later this evening. I'll take both if the construction matches the others I have at home.
    P.s. I had a mental picture when I came to work of the ones at home, but now I'm doubting a bit.
    Excellent detail on the photo's. It really helps show the construction.
  • snow
    snow Posts: 4,358
    heiney9 wrote: »
    No hurry I can wait :)
    Regards Snow
    Thanks Dan
    I'm going to pass, not the construction I'm trying match.
  • dromunds
    I'll take the Hytrons. Thanks
  • philm400
    philm400 Posts: 1
    I'll take RCA Short Grey plate 12AX7A-2-$7.50 each and the RCA short grey plate Halo getter 7025/12AX7-1-$20.00
    Thanks, Phil
  • Dawgfish
    Received the tubes today. They arrived quick and were well packed. I just put them in my modded JD-9 phono stage and they sound great! Thanks Snow!
  • snow
    snow Posts: 4,358
    Great to hear :)
    Regards Snow
  • mwk455
    mwk455 Posts: 219
    Received the cbs -jhy 5814a today . Fantastic sound thanks for the recommendation . Worth the price. Nice fast shipping . Thanks again
  • snow
    snow Posts: 4,358
    Great to hear :)
  • jonicont
    jonicont Posts: 281
    Arrived safe and sounding Telefunkin fine
  • snow
    snow Posts: 4,358
    Great to hear :)
  • GlennDog
    GlennDog Posts: 3,158
    What's left in the 12ax7 area?
    Pre Cary SLP-05
    Power Rogue M180 Dark monos
    Mains Salk HT2-TL
    Rythmik F12
  • snow
    snow Posts: 4,358
    GlennDog wrote: »
    It looks like these are still available.
    Regards Snow
  • vcwatkins
    vcwatkins Posts: 1,992
    I'll take these if still available:
    * Sylvania 5751 12AX7 short grey plate halo getter-1-$10.00
    * Sylvania 5751 12AX7 JAN-short grey plate halo getter-15-$10.00 each
    Thanks,
    Craig
  • vcwatkins
    Received these yesterday in excellent shape. Many thanks for the easy transaction and great deal.
    NOTE: I only bought 2 of the JAN 5751's - not all 15. So I imagine these are still available.
    vcwatkins wrote: »
    Thanks,
    Craig
  • [Deleted User]
    [Deleted User] Posts: 10,716
    bump to find out what if any
    12AU7 tubes are left...
  • snow
    snow Posts: 4,358
    edited August 2016
    Hi I have these left.
    1.RCA Cleartop side getter 12AU7A-4-$10.00 Each
    2.RCA Long grey plates D getter-1-$20.00
    3.Westinghouse 12AU7 Short grey plates halo getter-1-$7.50
    4.Mullard 12AU7 Short grey plates Halo getter-$20.00
    5.Sylvania 6189W grey plates halo getter-4-$7.50 each
    6.GE 6189 Grey plates halo getter-1-$7.50
    7.GE 12AU7 Halo getter grey plates 1-$7.50
    8.GE 6680 Grey plats hao getter-1-$10.00
    Regards Snow
  • snow
    snow Posts: 4,358
    Updated partial list of tubes still available some new ones have been added.
    1.RCA made Webcor labeled 12AX7 Black plates D getter-$30.00
    2.Amperex-12AX7-Gray Plate D getter-1-$40.00
    3.Amperex-12AX7-Gray Plate Halo getter-1-$25.00
    4.Mullard Made GE labeled Grey plate Halo getter 12AX7A-1-$20.00
    5.RCA Short Grey plate 12AX7A-1-$7.50
    6.RCA short grey plate Halo getter 7025/12AX7-1-$20.00
    7.Webcor labeled RCA made 12AX7-D getter Long Black plates-1-$30.00
    8.RCA Black plate 7025 D getter-1-$40.00
    9.RCA 7058/12AX7-Grey plate Halo getter-2-$25.00 each
    10.Sylvania 12AX7 short grey plates Halo getter-1-$7.50
    11.6680/12AX7-Grey plate Halo geter-1-$25.00
    12.GE 12AX7 long grey plate Halo getter-1-$7.50
    13.GE 12AX7 Short grey plate Halo getter-1-$7.50
    14.GE long grey plate 12AX7 Horse shoe getter-1-$10.00
    15.GE 5751/12AX7 short grey plate halo getter-1-$10.00
    16.GE 5751/12AX7 triple Mica grey plate halo getter-2-$25.00 each
    17.GE 5751/12AX7 triple Mica grey plate Horseshoe getter-1-$25.00
    18.GE 5751/12AX7 JAN- short grey plate halo getter-18-$10.00 each
    19.Sylvania 5751 12AX7 JAN-short grey plate halo getter-15-$10.00 each
    20.Sylvania 12AX7 JAN-short grey plate D getter- $25.00
    21.Westinghouse 12AX7A Grey plates D getter-4-$20.00 each
    22.Raytheon /Lowery labeled 12AX7A- Grey plate Halo getter-6-$7.50 each
    23.Packard Bell labeled GE made 12AT7 Triple mica D getter grey plate-1-$20.00
    24.RCA 12AT7WA Black Plate triple mica-1-$25.00
    25.RCA Black plate D getter-1-$20.00
    26. RCA 12AT7 Halo getter Grey plates-4-$7.50 each
    27.Sylvania JHS 12AT7WA triple mica grey plate D getter-2-$25.00 each
    28.GE 12AT7 Grey plates D getter-1-$15.00
    29.GE 6201 Greyplates halo getter-2-$7.50 each
    30.GE 6679 Black plates halo getter-1-$10.00
    31.GE 6679 GREY PLATES Halo getter-1-$7.50
    32.Sylvania 12AT7 WC Black plate Halo geter-1-$10.00
    33.Amperex 12AT7 France-1-$25.00
    34.Tung-Sol 12AT7 Halo getter Grey plates-1-$7.50
    35.Mullard 12AT7 HALO GETTER-2-$25.00 Each
    36..RCA Cleartop side getter 12AU7A-4-$10.00 Each
    37..RCA Long grey plates D getter-1-$20.00
    38.Westinghouse 12AU7 Short grey plates halo getter-1-$7.50
    39.Mullard 12AU7 Short grey plates Halo getter-$20.00
    40.Sylvania 6189W grey plates halo getter-4-$7.50 each
    41.GE 6189 Grey plates halo getter-1-$7.50
    42.GE 12AU7 Halo getter grey plates 1-$7.50
    43.GE 6680 Grey plats hao getter-1-$10.00
    44.Amperex 6DJ8-4-$15.00 Each
    45.GE-6DJ8-NOS-2-10.00 Each
    Regards Snow
