Need help with a Mini Monitor crossover
the crossover in the MM have 2 resisters 2.7ohms & 1.0 ohms. Looking at schematics of other Monitor series(5jr, 5B, & 7's) they show replacing the 2.7 with a 2.0 ohms. Should I do that mod. here or keep the 2.7 resister? Also what does the change from 2.7 to 2.0 do for the speaker? Thanks for your help. MP
  • codycatalist
    codycatalist Posts: 2,661
  • codycatalist
    edited June 2016
    Per Crossover;
    Caps
    (1) 12uF 50V or higher
    (1) 34uF 50V or higher
    Resistors
    (1) 1ohm 5W or higher
    (1) 2.7ohm 5W or higher
    For caps I like Sonicap, Clarity are also good. For resistors I like MIlls.
    You should remove the fuses and clean the ends as well as the holder clips.
    ***EDIT**** Welcome to the Forum!
  • codycatalist
    @F1nut Do you know what difference changing the values will have on the MMs?
  • westmassguy
    westmassguy Posts: 6,850
    Pull one of your crossovers, and verify the values for all components. Do not change them when upgrading. Polk revised their schematics because of design changes. For example, when a fuse was deleted and replaced with a Polyswitch, the resistor value downstream was reduced to compensate. Another example, if a different tweeter was used, the resistor and capacitor in series with it may change, and the shunt inductor and resistor (if equipped) may change as well.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Musicplayer
    Thanks to everyone that answered my post, I'll will just update using the same size. I do have one more question for Westmassguy. When I got these MM's the original mid/woofers were gone and had been replaced with a pair of 4" sparkamatic series 8000 car speakers. In a past post you mentioned that Polk used CTS speakers in some speakers, do you know if they were used in the MM's and were the original speakers 4 or 8 ohms. Thank you for your help. MP
  • westmassguy
    CTS and Rola made essentially the same woofer back then. I'm very familiar with the 8 ohm version, but I believe Polk used the 4 ohm version. Several CP Members own the mini monitors, so they'd be the best source to verify 4 or 8 ohm.
