Why does Mp3 format add a gap between songs?
machone
machone Posts: 1,565
I am new to Jriver.
I ripped cds to wave files and everything is correct but when I convert them to Mp3 I get a gap. Very annoying with music like DSOTM.
1KVA Dreadnought
Marantz SA 8005
Sony PS4
  • skrol
    skrol Posts: 3,462
    You need a player that does gapless. There are very few players that do.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Is there any way to rip the entire disk as a single file?
  • skrol
    skrol Posts: 3,462
    Exact Audio Copy (EAC) can rip to a single FLAC file, possibly to mp3. Problem would be that you can't skip to the next song very easily
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • machone
    I am not a fan of Mp3 anyway. The only reason I have them is to play them in my car. I am planning to buy a new head end that will play wave and flac. Until then I won't worry about the gaps.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • D'prived
    D'prived Posts: 191
    skrol wrote: »
    EAC will rip a CD as one track in MP3 format. It's not hard to do... I can't remember how to do it off the top of my head without the software in front of me.
  • Gatecrasher
    Gatecrasher Posts: 1,538
    Most digital ripping software will give you the option of adding gaps between tracks or not. I almost always have the feature turned off since I want exact duplicates of the original CDs.
  • Gatecrasher
    edited August 2016
    skrol wrote: »
    That's why you have a "cue sheet" file.
